Machinists, removing pistons from press fit rods #207537
01/29/09 10:46 AM
01/29/09 10:46 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Anybody on here able to successfully remove press fit pistons without damaging them? Ive got a set of KB quench dome pistons on 6 pack rods that I want to have removed, mill the quench domes and then put back on.
Ive called a few semi local shops and nobody will touch em, even though Ive heard of guys doing it with success before.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Machinists, removing pistons from press fit rods [Re: Von] #207538
01/29/09 10:59 AM
01/29/09 10:59 AM
God's Country Maryland
GODSCOUNTRY340 Offline
They'll press out a lot easier if you heat the rod first. Those shops are most likely afraid the KB pistons will break. I've installed them without a press, just heat the rod end and have the wrist pins in your freezer overnight. They will push in by hand a lot of times, maybe just a little nudging with a brass punch.
Re: Machinists, removing pistons from press fit rods [Re: Von] #207539
01/29/09 11:06 AM
01/29/09 11:06 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I have done it before but I doubt you get a shop that will guarantee it.
Re: Machinists, removing pistons from press fit rods [Re: Von] #207540
01/29/09 11:12 AM
01/29/09 11:12 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
You should be able to machine them off without taking off the rods. Chuck them up in the mill and just swing the rod out of the way.
Re: Machinists, removing pistons from press fit rods [Re: Von] #207541
01/29/09 12:35 PM
01/29/09 12:35 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
It is possible but I couldn't find a shop to do it for me either, a buddy did. He heated the small end w/ a torch and pressed the pins out.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Machinists, removing pistons from press fit rods [Re: Von] #207542
01/29/09 01:56 PM
01/29/09 01:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've done it a couple of times useing a torch, no
big deal. When you put them back on, heat it up
(rod end) and slide the pin in... make sure its centered
and you wont have much time till the rod will grab
the pin(you dont have to rush but dont dilly dally)
Re: Machinists, removing pistons from press fit rods [Re: MR_P_BODY] #207543
01/29/09 06:29 PM
01/29/09 06:29 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My machinist can do it.He even pressed the pins out of my old 30 year old pistons with no problems.You need a good shop.Rocky
Chrysler Firepower
Re: Machinists, removing pistons from press fit rods [Re: therocks] #207544
01/29/09 09:10 PM
01/29/09 09:10 PM
N.E. Alabama
64dodge440 Offline
64dodge440  Offline
N.E. Alabama
I machined a radius in a oak 4x4 to help support around piston and drilled a hole for the pin to go thru. Used a torch on the rod and pin pressed out fairly easy. They have been running after that for about 12 years now.
Re: Machinists, removing pistons from press fit rods [Re: 64dodge440] #207545
01/29/09 09:31 PM
01/29/09 09:31 PM
North West,Ohio
SSDA3426 Offline
SSDA3426  Offline
North West,Ohio
Muscle Motors will Do Them...They MAY even be able to Deck the Piston to Size for you.They are in an ad Header here...You Can Contact them at 888-482-4900 Ask For AL(He more than likely will answer the phone.Also Goes By Eric) and tell him J.D. Referred you..
I have done BOTH Jobs Myself BUT if you are wanting to reuse a set of KB Pistons I would deffinately send them out without experience....
SS
Re: Machinists, removing pistons from press fit rods [Re: Von] #207546
01/30/09 08:25 AM
01/30/09 08:25 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
torch, press and a pin just smaller than the wrist pin
my oldsmobile has press pins
Re: Machinists, removing pistons from press fit rods [Re: Von] #207547
01/30/09 10:44 AM
01/30/09 10:44 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Done it a few times. Heat the rod end and press out. Heat the rod end and cool the pin upon assembly just like was said. No issues.
Damon
Re: Machinists, removing pistons from press fit rods [Re: Von] #207548
01/30/09 10:56 AM
01/30/09 10:56 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Its not the fact that you are simply pressing the rods thats the concern, as someone mentioned, its the fact that they are KB Hypers, and yes they are way more crack prone when pressing. With a piston press ( the RIGHT one) it will support the rod pin boss, and not the skirt or pin boss of the piston only. A good piston fixture is $600-800, thats just for the fixture, and not the press etc. Buy a whole Sunnen set up and its thousands of dollars. So my point is, make sure they have a fixture that supports the rod pin boss the proper way and you'll be fine. They will most likely want to heat the rod end on a hyper piston.
Any good quality shop should be able to handle it.
Re: Machinists, removing pistons from press fit rods [Re: Von] #207549
01/30/09 09:11 PM
01/30/09 09:11 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Tudors machine in Tulsa can do it i believe. My friend blew up a 350 a few years ago that had KB hyper pistons in it, they had a fixture to support the rod and not put pressure on the piston. This was years ago tudors may not even be around anymore.
68 Barracuda Formula S 340
Re: Machinists, removing pistons from press fit rods [Re: Bad340fish] #207550
01/31/09 12:43 AM
01/31/09 12:43 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
[Tudors machine in Tulsa can do it i believe. My friend blew up a 350 a few years ago that had KB hyper pistons in it, they had a fixture to support the rod and not put pressure on the piston. This was years ago tudors may not even be around anymore.
Thanks for the reply. FWIW, Ive never heard of Tudors, but I'll see if I can fine em.
Re: Machinists, removing pistons from press fit rods [Re: Von] #207551
01/31/09 01:36 AM
01/31/09 01:36 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't know if you from tulsa or not but they are just off of peoria on 3rd st.
1326 E 3rd St, Tulsa, OK - (918) 582-2231
FWIW I don't know if I would have them do anything else or not. They did the 340 that was in my car when I got it. It had a main bearing in wrong and was bored all kinds of wrong it should never have ran. However, that was 14 years ago lol....they did a great job with my friends pistons.
Re: Machinists, removing pistons from press fit rods [Re: Von] #207552
01/31/09 10:51 AM
01/31/09 10:51 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
before sending them off
you might try pre-heating the connecting rod
with an electric heat gun (safer than torch's flame)
and then packing the inside of the pin
with dry ice more and more until is stays solid
and if all goes well
the pin might then fall out
dry ice is not too expensive
usually about $6 per pound
and I would guess it will take about
half a pound per pin
