SR port flow #207522
01/29/09 10:24 AM
01/29/09 10:24 AM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
Porting and flowing jsut completed on my Indy SR heads. Previously the heads had only been opened to MW size with a clean up. Turned out they were flowing right around 300 on the intake and 240 on the exhaust at .700 lift. Porting and a new valve job increased flow by roughly 50 CFM on both intake and exhaust. Do not have the sheets yet they are coming with the heads.
While these are not a big as some of the numbers I have heard from these heads I am pretty pleased with a 50 CFM increase.
Previously the 493 dynoed 669 hp with a sold roller 280 @0.050 with 700 lift at 12:1
With the porting and roughly a 1 point compression increase (milled heads)any guesses what kind of hp increase should be expected. How about ET (previously 9.85).
thanks
76 Duster work in progress
Re: SR port flow [Re: Edge] #207523
01/29/09 11:09 AM
01/29/09 11:09 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
743 HP and 9.48
Re: SR port flow [Re: S/ST 3040] #207524
01/29/09 02:06 PM
01/29/09 02:06 PM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
I would be real pleased if the car would run a 9.50. It is kind of the target I was shooting for. But things always seem to work better on paper.
I am also putting on a glass hood and bumpers (VFN) to drop a few more pounds. Going to try the 5 inch hemi scoop (hope its not too ugly) have not seen the scoop yet.
Re: SR port flow [Re: Edge] #207525
01/29/09 02:43 PM
01/29/09 02:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Nick Wilsons 64 Belvedere ran 9.30@3700lbs+ at Norwalk in September. Its a N/SS,Max Wedge style car running a 572,SRs,Indy crossram,leaf springs w/ Cal Tracks. I was Impressed. Nick runs Compu-Flow in Ohio.
Doug
Re: SR port flow [Re: dvw] #207526
01/29/09 05:07 PM
01/29/09 05:07 PM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
That is impressive for a big car. My goals are more humble as our track is close to 3700 foot elevation and the mountain air that blows while clean is normally not great for making hp. I would like one day to take a stab at a sea level run ( probably tear my block apart)but would run a nice number while it lasted
Re: SR port flow [Re: dvw] #207527
01/29/09 07:42 PM
01/29/09 07:42 PM
griff70440 Offline
griff70440  Offline
Nick Wilsons 64 Belvedere ran [Email]9.30@3700lbs+[/Email] at Norwalk in September. Its a N/SS,Max Wedge style car running a 572,SRs,Indy crossram,leaf springs w/ Cal Tracks. I was Impressed. Nick runs Compu-Flow in Ohio.
Doug
I seen Nick run a 9.25 @ tomspon.I was Impressed too.I just picked up a pair of -1s from him!
Re: SR port flow [Re: griff70440] #207528
01/29/09 08:59 PM
01/29/09 08:59 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Should see 50-75 hp gain at least.
Re: SR port flow [Re: Bob_Coomer] #207529
01/29/09 09:07 PM
01/29/09 09:07 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
EDGE
what dos your car weigth ?
1.39 9.85 - 137 mph
Re: SR port flow [Re: Ari440] #207530
01/30/09 04:21 PM
01/30/09 04:21 PM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
I have not weighed the car for a year or so and always making little changes. However should be just under 3000 LBS in the staging beams.
Re: SR port flow [Re: Edge] #207531
01/30/09 04:51 PM
01/30/09 04:51 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I hope my 64 will be close to Nicks.-1 heads,15-1,.800" roller,same intake,572. I've really been diligent about wieght removal. Hope to be 3300lbs or less with driver. We will see. Nicks a sharp guy. We'll see how on the ball I am.
Doug
Re: SR port flow [Re: Edge] #207532
01/30/09 05:55 PM
01/30/09 05:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would think you can make 760hp
