Re: Breaking in an engine with a self learning EFI?
[Re: Adam71Charger]
#2075159
05/17/16 03:21 PM
05/17/16 03:21 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
It should be fine. Your biggest concern will be timing.
[Re: Adam71Charger]
#2075284
05/17/16 07:04 PM
05/17/16 07:04 PM
Posts: 75,047 U.S.S.A.
JohnRR
U.S.S.A.
I may, or may not, depending on funds, be able to score a holley terminator EFI for my 440 build. If I do, I am wondering if there is any issues with using it for the initial break in? Flat tappet cam and is the system USED and already run on another engine ?? Me , if it's a flat tappet cam I would do it with a carb and then swap on the EFI ...
