cuda headliner install
#2072898
05/13/16 09:28 PM
05/13/16 09:28 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
Im getting ready to install the headliner in my 73 cuda. The problem is the entire interior was gutted in the car and everything was missing when I got it. I bought a set of bows for the car being under the impression that the only thing that held the headliner in place were the bows, glue and tack strips but now I see that they sell headliner retaining clips and anchors for the rear bows. Where do these go? Any pictures would be helpful. thanks
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: cuda headliner install
[Re: 73cuda340]
#2073638
05/15/16 12:29 AM
05/15/16 12:29 AM
Posts: 755 Oregon
moparmedic
You don't need the clips. They are nice to have but not necessary for the installation. I just use glue on the roof rails to hold the headliner in place.
1968 Coronet 1968 Charger 1966 A100 Pickup 1967 Barracuda 1970 Challenger 1972 Challenger 1973 Barracuda 2021 Ram 2500
[Re: 73cuda340]
#2073663
05/15/16 01:18 AM
05/15/16 01:18 AM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
they go on edge or pinch weld you don't need them , watch the video on rest ricks website very helpfull . use spray glue on edge , tape off rest so you only have a inch or so of glue . you tube has some good videos
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
[Re: 73cuda340]
#2073960
05/15/16 05:29 PM
05/15/16 05:29 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I do not think I would have gotten mine in without the list wires on the back. They were needed to keep enough tension on the material to keep the headliner smooth. I used RestoRicks instructions. The wires I refer to are in step 6. They are available. I got mine on ebay. I used a couple of dozen bull dog paper clips and some rubber coated clips to hold stuff in place as I went before glueing and pushing the material in the spikes. BTW, there are more holes to put the bows into than there are bows. Figuring out which holes to use is also important. Good luck Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: mopar4ya]
#2074386
05/16/16 09:39 AM
05/16/16 09:39 AM
Posts: 1,487 STL
cdstl
STL
My first, and only, headliner install was in my Cuda. This was a helpful article. Hemmings headliner install
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: burdar]
#2074620
05/16/16 05:40 PM
05/16/16 05:40 PM
73cuda340
clarks summit pa
I bought the 4 bow setup and I believe that I have the bows installed in the correct order. I will try to post a picture later. I just ordered the tension wires on ebay so I'll have to wait for those to come in to do the install. The headliner that I ordered was the perforated style and not the Yorkshire. Hopefully it still goes well.
[Re: 73cuda340]
#2074681
05/16/16 07:24 PM
05/16/16 07:24 PM
73cuda340
clarks summit pa
Here's a picture of the bows installed. Does this look about right? I know that the bows are color coded, but I only remember seeing a little bit of orange paint on one of them and the rest are pretty much all worn off. I'm pretty sure that they're in the right locations, they seem to fit nicely side to side and they are snug against the roof. I guess I'll have to play with the different adjustment holes when it comes time to put it in.
[Re: 73cuda340]
#2075037
05/17/16 11:59 AM
05/17/16 11:59 AM
Posts: 1,023 pa.
dan9
pa.
You may want to put the screws part way in for the coat hooks, dome light, rear view mirror, sun visors shoulder belts etc. That way you can feel for them through the material to cut the holes.
[Re: burdar]
#2075064
05/17/16 12:39 PM
05/17/16 12:39 PM
denfireguy
Colorado
I will also add that if you buy the correct headliner for a 73, the install will go much easier. The correct Yorkshire material is very stretchy and installs much easier then the older style perforated material. You need to go through Dante or SMS to get the Yorkshire headliner. Correct Because of Burdar's headsup, I got the proper one from SMS. I have installed both the Legendary and the SMS headliners. The SMS is not only correct but also installed wrinkle free. It was far easier to get in place properly. Your picture looks correct. If the bows are in the wrong holes, the headliner will not even begin to go in properly. Craig
[Re: denfireguy]
#2075499
05/18/16 12:46 AM
05/18/16 12:46 AM
73cuda340
clarks summit pa
Ok thanks. Ill have to find a set of brackets for the seat belt hangers and the coat hooks as those are missing too.
[Re: 73cuda340]
#2096948
06/23/16 08:16 PM
06/23/16 08:16 PM
73cuda340
clarks summit pa
When installing the headliner bows, are the bows supposed to hold the headliner tight against the roof or is there supposed to be a little gap? When I try to install the headliner with the bows tight to the roof, I can barely get the headliner stretched far enough to get the bows into the holes. Every video that I've seen with the bow type headliners they installed effortlessly.
