aluminum radiators #207467
01/29/09 01:40 AM
01/29/09 01:40 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
who makes a good aluminum radiator for a 22" core support? all I see is ones for 26+. does anyone also have any pics of them installed in their cars? how did you hook up the trans cooler lines? thanks!
-kevin
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: aluminum radiators [Re: mopars_1] #207468
01/29/09 02:45 AM
01/29/09 02:45 AM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Mancini is selling OEM style aluminum replacements. Wizard Cooling and Smiths Radiator does too with integrated trans coolers. BeCool and most everyone else will require a change to crossflow and some additional adaptation for a 22" core support.
http://chucker54.stores.yahoo.net/mucaralra1.html
Re: aluminum radiators [Re: 70Duster440] #207469
01/29/09 08:55 PM
01/29/09 08:55 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
The core width of this summit unit is 22-3/8". The opening on a 22" core support.... You guessed it, 22-3/8".
Only issue here is the battery tray may interfere with the tank. (One more reason to put the battery in the trunk)
http://store.summitracing.com/partdetail.asp?part=SUM%2D381428&FROM=MG
Re: aluminum radiators [Re: StealthWedge67] #207470
01/29/09 09:08 PM
01/29/09 09:08 PM
hooziewhatsit Offline
www.radiatorbarn.com has both a 22" and a 26" radiator. It doesn't specify aluminum or otherwise though. They look like stock replacements.
Re: aluminum radiators [Re: mopars_1] #207471
01/30/09 08:56 AM
01/30/09 08:56 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I just read on another site that early 90's Ford Ranger radiators are supposed to fit the early Mopar cars with a 22" radiator and a drivers side lower outlet. I have yet to check one out, but it might be worth doing so.
This is the land of the free because of the brave
Re: aluminum radiators [Re: mopars_1] #207472
01/30/09 04:21 PM
01/30/09 04:21 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Nautilus Racing-
Re: aluminum radiators [Re: Chris2581] #207473
01/30/09 04:35 PM
01/30/09 04:35 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
www.alumorad.com
Wow, that's a good price!!!
Re: aluminum radiators [Re: cudarex] #207474
01/30/09 04:46 PM
01/30/09 04:46 PM
I've seen some aluminum radiators on Ebay for around $200. I'm not sure if they are any good, though.
Re: aluminum radiators [Re: mopars_1] #207475
01/31/09 10:25 PM
01/31/09 10:25 PM
Southern Wisconsin
hillsidehemi Offline
Southern Wisconsin
Wow the alumarad website has good prices. However I don't see a 22" radiator. Has anyone found one from them? I'd be interested in one. The last one I bought For the 63 Polara was on Ebay from radman who was out of the Detroit area I believe. Around $400 but the quality was excellent and the cooler was on the bottom where it is supposed to be.
Re: aluminum radiators [Re: hillsidehemi] #207476
01/31/09 11:21 PM
01/31/09 11:21 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
