Makrolon polycorbonate sheet for car windows? #2074509
05/16/16 02:05 PM
05/16/16 02:05 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
http://www.eplastics.com/Plastic/Transparent_Color_Polycarbonate_Sheet
Does this makrolon sheet work good for windshield and side windows?
This would be for my 31 Plymouth coupe, so it is all flat. Is it legal for NHRA racing and for street use? What thickness would I need, and what is the best way to mount it?
THanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Makrolon polycorbonate sheet for car windows? [Re: Hemi_Joel] #2074521
05/16/16 02:19 PM
05/16/16 02:19 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
It will work fine,use .250 since your glass is all flat.If your stock glass uses gaskets to hold the in place you can use them to hold plastic also.
Re: Makrolon polycorbonate sheet for car windows? [Re: Hemi_Joel] #2074663
05/16/16 06:55 PM
05/16/16 06:55 PM
Minnesota
Minnesota
Thanks Bob.
Originally the car had a heavy steel windshield frame that opened. I'm not doing that, and I don't have the frame anyway. I was thinking of bedding it in some caulk and fabbing some kind of system to clamp it in. Would that work, or does it need to have holes drilled and screwed in?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Makrolon polycorbonate sheet for car windows? [Re: Hemi_Joel] #2074696
05/16/16 07:49 PM
05/16/16 07:49 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I used 1/8" embedding it in the original channels. Works fine even at 150. If it were to be used on the street I personally would use 1/4".
Doug
Re: Makrolon polycorbonate sheet for car windows? [Re: Hemi_Joel] #2074705
05/16/16 08:22 PM
05/16/16 08:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Joel.. do you have wipers on it.. if so you wont use
them again... wipers will destroy the windshield (fog
it right up with scratches)... I went with glass on my
hot rod just so I could run wipers.. yeah.. I would have
loved going lexan due to the weight savings.. but I would
rather have the wipers
wave
Re: Makrolon polycorbonate sheet for car windows? [Re: Hemi_Joel] #2074711
05/16/16 08:34 PM
05/16/16 08:34 PM
Minnesota
Minnesota
No wipers yet. I suppose I could go either way on that. Rain-X seems to work pretty good if there's significant rain falling. Maybe not very good in a light mist though.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Makrolon polycorbonate sheet for car windows? [Re: Hemi_Joel] #2074716
05/16/16 08:50 PM
05/16/16 08:50 PM
fullmetaljacket Offline
P-body is correct. The wipers will blemish the lexan.
As a certain car on here has done and if you do not have wipers, consider your car the perfect meteorologist weather vane. If it is out and about on the street, that means you can bet it will be a sunny evening. LOL.
Good plastic polish keeps the Lexan looking new for years, but nothing beats real glass except it's own weight.
Re: Makrolon polycorbonate sheet for car windows? [Re: Hemi_Joel] #2074719
05/16/16 08:52 PM
05/16/16 08:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
One year on DW we were coming out of Milan Mi heading
to Pa and it was pouring so hard we almost had to stop
(I think it was 2010) and there was a tornado on the
route.. we had rain-x on Dales truck windshield and it
wasnt anywhere near enough.. from that moment on I KNEW
I was gonna run wipers.. and defrosters.... and I am...
Dale keeps talking about wipers but hasnt done them yet
wave
Re: Makrolon polycorbonate sheet for car windows? [Re: Hemi_Joel] #2074722
05/16/16 09:02 PM
05/16/16 09:02 PM
Minnesota
Minnesota
OK, I measured and calculated, it looks like the windshield would be 6.5 pounds heavier in glass. Close enuff for a car that will run the street. I'll go with glass in the windshield, plastic in the sides and back. Thanks for all the help!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Makrolon polycorbonate sheet for car windows? [Re: Hemi_Joel] #2074740
05/16/16 09:23 PM
05/16/16 09:23 PM
Good move.
Re: Makrolon polycorbonate sheet for car windows? [Re: Hemi_Joel] #2074755
05/16/16 10:03 PM
05/16/16 10:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Joel... will you be rolling the side windows up and down..
if so and you have the rubber seal that drags on the glass
you might want to rethink those also
wave
Re: Makrolon polycorbonate sheet for car windows? [Re: Hemi_Joel] #2074962
05/17/16 09:01 AM
05/17/16 09:01 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We did a 33 Plymouth coupe.We lined the frame with windshield seal/caulk and made a nice aluminium outer frame that we attached with stainless screws.
Re: Makrolon polycorbonate sheet for car windows? [Re: Hemi_Joel] #2074963
05/17/16 09:04 AM
05/17/16 09:04 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We did a 33 Plymouth coupe.We lined the frame with windshield seal/caulk and made a nice aluminium outer frame that we attached with stainless screws.We treated the side windows the same as glass and the .250 rolled up and down with ease.We did not use whiskers or rubber wipers to seal the windows.
Re: Makrolon polycorbonate sheet for car windows? [Re: B G Racing] #2074995
05/17/16 10:52 AM
05/17/16 10:52 AM
My whiskers do not interfere with my windows going up or down. In fact, they help keep the glass in its place on the tracks and keep 'em from rattling. Rubber seals will indeed hamper their travel though.
Re: Makrolon polycorbonate sheet for car windows? [Re: Hemi_Joel] #2075024
05/17/16 11:30 AM
05/17/16 11:30 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine go up and down in the original run channels and cat whiskers. Drag car but it hasn't hurt it yet,300 passes.
Doug
Re: Makrolon polycorbonate sheet for car windows? [Re: Hemi_Joel] #2075086
05/17/16 01:10 PM
05/17/16 01:10 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We found the whiskers and rubber wipers tend to get dirt in them and can scratch or dull the Markolon.If you use aircraft quality Lexan it is more durable.
Re: Makrolon polycorbonate sheet for car windows? [Re: B G Racing] #2075229
05/17/16 05:11 PM
05/17/16 05:11 PM
Aircraft quality.
