Re: Windage Tray Question
[Re: oldiron]
#2073495
05/14/16 07:44 PM
05/14/16 07:44 PM
Posts: 14,545 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'd add a few holes, and make sure it clears the rods.
[Re: fast68plymouth]
#2073503
05/14/16 07:54 PM
05/14/16 07:54 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Ok Thanks, Yes, I will maker sure and yes, the louvers are pretty tight, I thought I'd bend them open, Adding holes is something I'm good at. Will do!
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: oldiron]
#2073510
05/14/16 08:09 PM
05/14/16 08:09 PM
Posts: 4,220 New York
polyspheric
New York
Prying them open with a big screwdriver used to be in the Chrysler tips.
Boffin Emeritus
[Re: ek3]
#2074308
05/16/16 12:39 AM
05/16/16 12:39 AM
Posts: 43,986 Bend,OR USA
Cab_Burge
nice ! do they have one to fit / clear rb 512 strokers ? use a stock pan ? mfg part # ? What size rod journals and type of rods do you want to use? If BB Chevy stock rod sizes and steel H beam rods with rod bolts only with no nuts they usually clear real well on both RB and B 4.250 stroke motors with the stock Mopar windage trays If your using the stock Mopar rod journal sizes and Mopar rods you may have a problem with stock Mopar brand windage tray
[Re: ek3]
#2074311
05/16/16 12:53 AM
05/16/16 12:53 AM
Cab_Burge
I can buy the Mopar brand windage trays from Summit cheaper than I can buy them from the local Dodge and Chrysler dealers I bought a Milidon stroker windage tray also and they definetly will not work with a stock Mopar passenger car oil pan Maybe they fit thier race pans
[Re: ek3]
#2074357
05/16/16 04:21 AM
05/16/16 04:21 AM
Posts: 4,649 aotearoa
rebel
aotearoa
nice ! do they have one to fit / clear rb 512 strokers ? use a stock pan ? mfg part # ? Mine clears my 512 stroker with Eagle rods. In my pic that is a stock pan that I made deeper & set up for external pickup. I bought mine from Summit but I had to enlarge the holes a bit but nothing that couldn't be done with a small die grinder.
[Re: oldiron]
#2074413
05/16/16 10:14 AM
05/16/16 10:14 AM
Posts: 13,129 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
Summit Racing SUM-G2339 - Summit Racing® Molded Gasket Windage Trays
Summit Racing SUM-G2340 - Summit Racing® Molded Gasket Windage Trays
I used the 2340 with my 4.25 stroke, 2.2 journal, stock pan and pick-up. Other than opening up the drains a bit and adding a few more drains, I really liked this tray/gasket combo. I'll be using it in all my future builds.
Master, again and still
[Re: oldiron]
#2074466
05/16/16 11:48 AM
05/16/16 11:48 AM
Posts: 75,339 A gulag near you.
JohnRR
A gulag near you.
The stock louvers in the stock tray are pretty useless , can't figure out their real use?? I had a few stock trays louvered like the milodon tray because all that stock tray does is slow the flow of oil back to the pan sump.
The last one I used for a buddy I just drilled about 20 1/4 inch holes in a few rows to get the oil back tothe sump faster.
Mainstream Media is the new Pravda
