Pump Gas Gen 2 Hemis #2073989
05/15/16 06:20 PM
05/15/16 06:20 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
How high compression ratio are you getting away with on pump gas? Ive heard as high as 12:1 with aluminum heads. I know the chamber allows higher than some wedge stuff.
Re: Pump Gas Hemis [Re: Hot 340] #2073991
05/15/16 06:23 PM
05/15/16 06:23 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
What pump gas? Non ethanol? 91 or 93? 11.1 with aluminum heads is about the max in the REAL world IMO.
Mopar to the bone!!!
Re: Pump Gas Hemis [Re: 72Swinger] #2073998
05/15/16 06:34 PM
05/15/16 06:34 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
whats your combination? Are you seeing detonation at 11?
Re: Pump Gas Hemis [Re: Hot 340] #2074034
05/15/16 07:33 PM
05/15/16 07:33 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
No sir but mine is one of those 16 spark plug, flat top piston NOT A REAL Hemi.....Hemi's. It runs like a missle with 23* of advance. I shouldnt even be wasting your time by commenting lol! Are you building a new combo or wanting to make an existing combo work on pump gas? Is E85 an option?
Re: Pump Gas Hemis [Re: 72Swinger] #2074042
05/15/16 07:51 PM
05/15/16 07:51 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
New combination/new parts with old design gen 2 stuff. E85 is out for me, no place close by that sells it. 😟
Re: Pump Gas Hemis [Re: Hot 340] #2074049
05/15/16 07:57 PM
05/15/16 07:57 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I ran 11.6:1 in my 484 with no issues for years. I have a 605 hemi now, and I am right around 11.0-11.1:1 with no issues. The Hemi's are very resistant to having issues with detonation. I would be very comfortable running 12:1 on 93 and watching my timing and tune up. What we use around here is E10, so until they get rid of it, that's what I am running mine on.
I would not run any lower than 11:1 on pump gas with a hemi. If your building it, build it for 12:1 with .027 head gaskets, and switch to thicker ones if you have to.
Re: Pump Gas Hemis [Re: Dragula] #2074107
05/15/16 09:14 PM
05/15/16 09:14 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Just finished and dyno'd my 528 with a true 10.5:1 and it almost made 840 hp and 671 TQ.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Pump Gas Hemis [Re: 6PKRTSE] #2074122
05/15/16 09:31 PM
05/15/16 09:31 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I'm guessing on pump gas. What timing and cylinder pressure?
Re: Pump Gas Hemis [Re: Hot 340] #2074140
05/15/16 09:48 PM
05/15/16 09:48 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Sorry didn't catch the Hemroid part.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Pump Gas Gen 2 Hemis [Re: Hot 340] #2074319
05/16/16 02:10 AM
05/16/16 02:10 AM
I've built and dyno tested several different stock Mopar iron headed pump gas 426 type motors, 434 C.I., 3.91 stroke and 4.150 stroke motors for the same customer. All of them where right at 10.5 to 10.8 to 1 compression ratio and ran fine with CA pump swill back in the early 2000s shruggy I built the same customer a D5 alumimun headed 526 C.I. motor with a stock OEM Mopar cross ram with stock OEM Holley SS carbs., it struggle to make 50 HP more on the DTS engine dyno than the 4.150 stroke motor did with the new heavy Mopar iron replacement heads and a stock 1966 inline intake manifolds and stock 1966 AFB Carbs did confused shruggy That motor had a little over 12.5 to 1 compression, I probally should have treid it also on CA 91 octane pump swill work
Re: Pump Gas Gen 2 Hemis [Re: Hot 340] #2074369
05/16/16 07:48 AM
05/16/16 07:48 AM
nielsville, minn.
Q
quickd100 Online content
quickd100  Online Content
Q
nielsville, minn.
My 605 is 10.4-1, the reason I didn't go any higher is the best fuel locally is 87 octane. I have to drive 20-40 miles to buy 91. If you build a big bore hemi be very careful about using a head gasket .042 or thinner. My 528 had 4 pistons kiss the heads at zero deck and .042. I over revved it twice.Dave
Re: Pump Gas Gen 2 Hemis [Re: Dragula] #2074371
05/16/16 08:23 AM
05/16/16 08:23 AM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
I wouldn't go over 11.1 with the fuel in my area. Rated at the pump at 93 the rating is from when it left the refinery. A lot of the octane is achieved from the ethanol so as it ages I'm sure the octane drops. I run 10.4 with aluminum heads. I still mix in some race fuel when I race it. Unless you are trying to make max horsepower per cubic inch there are other ways to make horsepower than raising the compression.
Re: Pump Gas Gen 2 Hemis [Re: Hot 340] #2074398
05/16/16 10:29 AM
05/16/16 10:29 AM
an8sec70cuda Offline
Mine is 11:1.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Pump Gas Gen 2 Hemis [Re: Hot 340] #2074407
05/16/16 11:05 AM
05/16/16 11:05 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I bought my 540 reciprocating assembly and cam from Ray Barton. He spec'd the CR @ 10.5 for this aluminum headed street/strip motor. I asked him about more comp since I have ran 11:1 in my aluminum headed 499 wedge for years with no problems. He said there wasn't enough additional power for a primarily street driven engine to warrant the extra hassles.
Master, again and still
Re: Pump Gas Hemis [Re: 6PKRTSE] #2074474
05/16/16 12:54 PM
05/16/16 12:54 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Care to share the combo?
Re: Pump Gas Hemis [Re: cudadoug] #2074529
05/16/16 02:31 PM
05/16/16 02:31 PM
NW INDIANA
ta3834bbl Offline
ta3834bbl  Offline
NW INDIANA
Yes, I am very interested in your combo as well. I love to learn new stuff that works.
67 Dart GT Convertible 273
68 Barracuda 383
68 Roadrunner 383 4spd
1 '01 Ram 2500 4x4 diesel
2 '02 Rams 1500 4x4's 4.7s
3 '03 Rams 2 1500's 4x4 and 1 2500 hemi 4x4
Oh, and a 03 Grand Cherokee and an '00 durango smile
Re: Pump Gas Hemis [Re: Hot 340] #2074582
05/16/16 04:15 PM
05/16/16 04:15 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
our pump swill here is 85 octane, so I kept my 572 at 9.5 to one, that way I know that I can run any gas anywhere. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Pump Gas Hemis [Re: Hot 340] #2074585
05/16/16 04:21 PM
05/16/16 04:21 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
10.8:1 Iron block and heads 477 CID. No problems on pump gas. The cam plays a big part in how much compression you can get away.
Re: Pump Gas Hemis [Re: Dragula] #2074803
05/16/16 11:04 PM
05/16/16 11:04 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
any trouble with 12:1 on a hot day? That would be my concern.
Re: Pump Gas Gen 2 Hemis [Re: quickd100] #2074805
05/16/16 11:07 PM
05/16/16 11:07 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
10.4:1 on 87 is doing pretty good. thumbs
