Exhaust suggestions #2074209
05/15/16 11:09 PM
05/15/16 11:09 PM
Illinois
Tinman761 Offline OP
Illinois
Looking for suggestions for the best fitting resto exhaust for my coronet
Re: Exhaust suggestions [Re: Tinman761] #2074241
05/15/16 11:47 PM
05/15/16 11:47 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Might help if you told us the year and the engine
Also your budget
The top of the line is ECS
Re: Exhaust suggestions [Re: Tinman761] #2074306
05/16/16 01:37 AM
05/16/16 01:37 AM
Illinois
Illinois
No problem. 67 383-4bbl budget? Free of course. I'm not sure what a resto exhaust would cost
Re: Exhaust suggestions [Re: Tinman761] #2074335
05/16/16 03:19 AM
05/16/16 03:19 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I don't know anyone that does them for free.
ECS is the top of the line but the cost line probably scare the hell out of you.
Accurate is Mopar only.
Dale's Cuda Shop
Gardeners - I think that's what they are called.
I'd start with Accurate. I got head pipes from them and the rest from Dales.
Re: Exhaust suggestions [Re: Morty426] #2074402
05/16/16 10:52 AM
05/16/16 10:52 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Accurate! up
Admiration For Multiple Carburetor Vehicles...
Re: Exhaust suggestions [Re: Tinman761] #2074441
05/16/16 12:19 PM
05/16/16 12:19 PM
Jacksonville, Fl
426runner Offline
426runner  Offline
Jacksonville, Fl
I went with Gardner, however...
The angle of the "cup" to the drivers manifold was off and leaked. Since the HEMI head pipe mount is that rounded "ball and cup" type joint, it still connected, but barely. I eventually removed the system, cut out a slight wedge, bent it into place and welded it into a better angle. I still had to use a hand made gasket and use some gasket sealer to stop the "tic-tic-tic...". Gardner claimed it was my use of repop manifolds. Maybe the leak was due to the repop but not the off angle. Other than that, very nice materials and construction. Looks very original.
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: Exhaust suggestions [Re: Tinman761] #2074457
05/16/16 12:39 PM
05/16/16 12:39 PM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
Does ECS make the exhaust for that application? I checked their website and it only shown 68-70 B-Body options. True ECS is more costly, but the fit and look are exact.
Re: Exhaust suggestions [Re: B5Cuda440-6] #2074862
05/17/16 12:24 AM
05/17/16 12:24 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I didn't think they would so I list Accurate
Re: Exhaust suggestions [Re: Morty426] #2075377
05/17/16 09:41 PM
05/17/16 09:41 PM
BlueRacer69 Offline
BlueRacer69  Offline
Same here, Accurate LTD. Nice system.
Re: Exhaust suggestions [Re: BlueRacer69] #2075403
05/17/16 10:26 PM
05/17/16 10:26 PM
MD
floyd Online content
floyd  Online Content
MD
Check out Don's Custom Exhaust for the head pipes.
http://www.donscustomexhaust.com/
Re: Exhaust suggestions [Re: Tinman761] #2075495
05/18/16 12:39 AM
05/18/16 12:39 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I have used Don's head pipes on several vehicles and they do have all the correct flat spots, creases and indents patterned from using originals...excellent pipes and excellent fit.
Re: Exhaust suggestions [Re: Tinman761] #2075736
05/18/16 11:41 AM
05/18/16 11:41 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What are you using for exhaust manifolds ? The 383 in 67 I do not think used the HP manifolds so they would be LOG manifolds with a 2" outlet and did that car even have the option of duals ?
Re: Exhaust suggestions [Re: Tinman761] #2075845
05/18/16 02:29 PM
05/18/16 02:29 PM
Illinois
Illinois
John, I am using the stock exhaust manifolds. I am just replacing what was on there from the previous owner.
Re: Exhaust suggestions [Re: Tinman761] #2076011
05/18/16 06:28 PM
05/18/16 06:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Single or duals ?
Re: Exhaust suggestions [Re: Tinman761] #2076205
05/18/16 11:48 PM
05/18/16 11:48 PM
MO
cdp Offline
cdp  Offline
MO
you may try http://www.waldronexhaust.com
I bought a kit for a 71 383 RR. Yet to install, but home to have it in within a few months.
If they don't have it listed, call them, because they have a book/print to bend by.
Full turndown kit was around $650 shipped.
Re: Exhaust suggestions [Re: Tinman761] #2076606
05/19/16 05:17 PM
05/19/16 05:17 PM
Illinois
Illinois
There were duals on it when I bought it. Thinking about going with accurate. Price seems fair.
Re: Exhaust suggestions [Re: floyd] #2077135
05/20/16 03:06 PM
05/20/16 03:06 PM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
Just installed a accurate exhaust 70 challenger fits great
Re: Exhaust suggestions [Re: Tinman761] #2077154
05/20/16 03:33 PM
05/20/16 03:33 PM
None
71rm23 Offline
71rm23  Offline
None
Looks great ct440rod. How was it putting the system in? Was it easy as their site says?
Re: Exhaust suggestions [Re: 71rm23] #2078362
05/22/16 05:28 PM
05/22/16 05:28 PM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
Was a great fit. Looks good. .
Re: Exhaust suggestions [Re: Tinman761] #2078572
05/23/16 12:37 AM
05/23/16 12:37 AM
Illinois
Illinois
Did you go with the stock muffler, or did you go more aggressive. It looks fantastic
