Re: 1993 W250 46RH Shifting in/out of OD at Strange Times [Re: ruderunner] #2071841
05/12/16 01:09 AM
05/12/16 01:09 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Thanks for the lesson guys, very informative!
I'll try the TPS first. I don't know about the 32MPH thing either. This truck has never shifted into OD at less than 50MPH.
Re: 1993 W250 46RH Shifting in/out of OD at Strange Times [Re: Jeremiah] #2071906
05/12/16 07:26 AM
05/12/16 07:26 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
You could try adjusting the tps.
Check out Geno's garage website for the how to
Angry white pureblood male
Re: 1993 W250 46RH Shifting in/out of OD at Strange Times [Re: ruderunner] #2071999
05/12/16 12:44 PM
05/12/16 12:44 PM
Guitar Jones Online laugh2
Sounds like either the TPS was bad for awhile or out of adjustment as well. Either way I still think you need to replace it and most likely adjust it after you replace it.
Re: 1993 W250 46RH Shifting in/out of OD at Strange Times [Re: Guitar Jones] #2073273
05/14/16 02:42 PM
05/14/16 02:42 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I will look up the adjustment procedure on the FSM, thanks for the tip.
I'm replacing the TPS when UPS drops it off. No time for malfunctioning equipment around here, we are trying to make money!
Re: 1993 W250 46RH Shifting in/out of OD at Strange Times [Re: Jeremiah] #2074823
05/16/16 11:24 PM
05/16/16 11:24 PM
Ohio (OH)
O
ohiojohn Offline
ohiojohn  Offline
O
Ohio (OH)
hello everyone ,i am new here and have owned my 92 since 96 and have had vss go bad several times, when one of them went bad speedo worked fine but od would not work at all. another went bad and speedo quit and od worked fine. yet another went bad and od would shift erratic. the last time i had one go bad it looked like it had plastic melted inside of it so when i installed the new one i put a drop of trans fluid in it and that has been close to ten years.
Re: 1993 W250 46RH Shifting in/out of OD at Strange Times [Re: ohiojohn] #2074923
05/17/16 02:39 AM
05/17/16 02:39 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Welcome aboard John!
Thank you for the info. Where exactly did you put the trans fluid? Hopefully we will have parts tomorrow.
Re: 1993 W250 46RH Shifting in/out of OD at Strange Times [Re: Jeremiah] #2079993
05/25/16 01:36 PM
05/25/16 01:36 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Okay, I installed the TPS first and it seems to have cured my issue. I'm going to tow a trailer around today so that should be a good test.
Thanks again to everyone for the help!
Re: 1993 W250 46RH Shifting in/out of OD at Strange Times [Re: Jeremiah] #2080118
05/25/16 04:30 PM
05/25/16 04:30 PM
So at what speed is it going into O/D now unloaded at light throttle?
Re: 1993 W250 46RH Shifting in/out of OD at Strange Times [Re: Guitar Jones] #2080149
05/25/16 05:22 PM
05/25/16 05:22 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
: ) About 32 MPH sir.
Re: 1993 W250 46RH Shifting in/out of OD at Strange Times [Re: Jeremiah] #2080214
05/25/16 07:35 PM
05/25/16 07:35 PM
Perfect
Re: 1993 W250 46RH Shifting in/out of OD at Strange Times [Re: Guitar Jones] #2080462
05/26/16 01:54 AM
05/26/16 01:54 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I towed a 2000 lb. tag 115 miles today and burned a little under a 1/4 tank of fuel. Transmission operation was flawless.
Thanks again for all of your help on this Mr. Jones. If you ever get up to this neck of the woods lunch is on me!
Re: 1993 W250 46RH Shifting in/out of OD at Strange Times [Re: Jeremiah] #2081170
05/27/16 10:40 AM
05/27/16 10:40 AM
You're welcome and thanks for the offer but I don't ever see me coming up there.
Re: 1993 W250 46RH Shifting in/out of OD at Strange Times [Re: Guitar Jones] #2081854
05/28/16 03:13 PM
05/28/16 03:13 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Unfortunately my truck got wrecked yesterday when an older fellow turned into the front passenger side and we all went into the ditch! Sad day, it sure was a nice truck.
Re: 1993 W250 46RH Shifting in/out of OD at Strange Times [Re: Jeremiah] #2082152
05/29/16 02:42 AM
05/29/16 02:42 AM
So sorry.
