Manual disc brakes #2072476
05/13/16 09:36 AM
05/13/16 09:36 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I am planning to upgrade to manual disc brakes in an E body small block Cuda (the car only has about 11" of vacuum at idle) from manual drum brakes. I'm wanting to know if it will stop well enough, ie anyone has found a manual disc set up to be less than sufficient? Thanks
Re: Manual disc brakes [Re: UCUDANT] #2072477
05/13/16 09:43 AM
05/13/16 09:43 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I recently swapped from manual drums to manual disc and a 15/16" master cylinder on my 340 Challenger. The car stops with no problems at all!
Re: Manual disc brakes [Re: UCUDANT] #2072478
05/13/16 09:43 AM
05/13/16 09:43 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
I've had Wilwood manual discs on two different cars and they both stopped awesome.
Re: Manual disc brakes [Re: Tempest] #2072503
05/13/16 10:48 AM
05/13/16 10:48 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
The 69 Dart has manual disc that work great. I robbed everything from a 74 Dart 4 door car.
I made sure to save the original brake proportioning block and used a 15/16" Aluminum Master Cylinder and 4-2 bolt adapter from Dr. Diff. No regrets...
...FAFO...
Re: Manual disc brakes [Re: UCUDANT] #2072505
05/13/16 10:50 AM
05/13/16 10:50 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I've got 4-wheel manual disks on my '71 Charger and have never missed having a power booster.
Re: Manual disc brakes [Re: UCUDANT] #2072510
05/13/16 10:55 AM
05/13/16 10:55 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I have a big block in my 70 Cuda and run a KOS class at the local track. It has discs on the front from a Chrysler Cordoba and stock rear drums. They are manual.
The car stops fine from over 100MPH even when hot lapping.
Master, again and still
Re: Manual disc brakes [Re: UCUDANT] #2072582
05/13/16 01:33 PM
05/13/16 01:33 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
The manual disc with the 15/16" master cylinder isn't bad on the Cuda. It doesn't feel like new car power brakes, but its fine for normal driving. Maybe its only my imagination, but I felt the pedal effort was reduced when upgrading the rotors from the factory size to the 11.75.
Re: Manual disc brakes [Re: UCUDANT] #2072912
05/13/16 09:50 PM
05/13/16 09:50 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I had manual front discs on mine before I tore it down, it was ok for the street. Given I will be road coursing my car, I'm heavily considering going to hydro-boost..
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Manual disc brakes [Re: GoodysGotaCuda] #2072933
05/13/16 10:16 PM
05/13/16 10:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Talk about no feel
Don't be the exception.
Re: Manual disc brakes [Re: Supercuda] #2072984
05/13/16 11:44 PM
05/13/16 11:44 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Talk about no feel
And that's the major downside of the idea.
2020 RAM 1500
Re: Manual disc brakes [Re: GoodysGotaCuda] #2073004
05/14/16 12:25 AM
05/14/16 12:25 AM
IN
ahy Offline
ahy  Offline
IN
My understanding, the details make a lot of difference to get a workable setup. Smaller bore master, plenty of brake piston area, and higher friction pads. The low cost organic pads bite well cold... but do not hang in there hot. Higher temp capable pads tend to be soft when cold and you may not be happy w/o booster.
As far as vacuum for a booster, you are not far off. My junk ran 9" vacuum before idle tuning. With more advance and mixture dialed in, it made 13" and vacuum boosted brakes work fine.
Re: Manual disc brakes [Re: UCUDANT] #2073074
05/14/16 02:27 AM
05/14/16 02:27 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
My 70 Duster 340 had manual disk brakes and they worked great
Re: Manual disc brakes [Re: UCUDANT] #2073114
05/14/16 09:04 AM
05/14/16 09:04 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thanks ALL
Anyone have a good P/N and source for the correct master cylinder and proportioning valve for my application? (1972 Cuda with stock 4 wheel drum brakes adding 1973 Cuda stock style front MANUAL disc)
"The brake answer man" seems extremely knowledgeable and stated he has the best available offerings? This board has allot of experience and knowlege so input is always welcome
Re: Manual disc brakes [Re: UCUDANT] #2073631
05/15/16 12:20 AM
05/15/16 12:20 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I used a 2-bolt Master cylinder from an early 80's Aspen I bought from NAPA and installed Dr Diff's 4-to-2 bolt conversion bracket and adjustable pushrod.
Re: Manual disc brakes [Re: UCUDANT] #2073691
05/15/16 02:48 AM
05/15/16 02:48 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I used a late 70s Volare MC so that it still had 4 bolts and it bolted right up.
Re: Manual disc brakes [Re: UCUDANT] #2073725
05/15/16 09:27 AM
05/15/16 09:27 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I'm using a Raybestos MC36406 as was recommended by Dr. Diff when he sold me the rear disks.
