Re: dash pad stud thread size?
[Re: JMCFAN]
#2072741
05/13/16 05:12 PM
05/13/16 05:12 PM
Posts: 1,317 Ohio
jlatessa
Ohio
[Re: 5carguy]
#2073299
05/14/16 03:21 PM
05/14/16 03:21 PM
Posts: 21,424 It's a dry heat
gtx6970
It's a dry heat
I think they look something like this. Bob, those are the screws that hold the dash frame to the body. the pad is attached with the above 10-24 stamped steel machine thread nut
[Re: gtx6970]
#2073461
05/14/16 07:54 PM
05/14/16 07:54 PM
Posts: 2,404 Lee Co. Fla.
5carguy
Lee Co. Fla.
I think they look something like this. Bob, those are the screws that hold the dash frame to the body. the pad is attached with the above 10-24 stamped steel machine thread nut Thanks Bill,you are right
[Re: gtx6970]
#2073987
05/15/16 06:19 PM
05/15/16 06:19 PM
Posts: 2,592 None
71rm23
None
I think they look something like this. Bob, those are the screws that hold the dash frame to the body. the pad is attached with the above 10-24 stamped steel machine thread nut Bill: You have the hardware that holds the dash to the body and the dash pad to the dash frame? Thanks
