Re: A100 big block?
[Re: earlymopar]
#2072514
05/13/16 11:02 AM
05/13/16 11:02 AM
Posts: 43,523 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I know where there is a van with a 413 in it, and used to own one with a 426 wedge. Seems to me you just use 61-71 Sweptline truck motor mounts. Here are some pics of it. I don't think the engine cover fits real well with an RB in it...
JB Rhinehart, Realist
A-Body's RULE!
Re: A100 big block?
[Re: kams]
#2072754
05/13/16 05:21 PM
05/13/16 05:21 PM
Posts: 16,474 On the run…
BloFish
On the run…
Dog house will not fit without some serious modifications.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
Re: A100 big block?
[Re: kams]
#2072779
05/13/16 06:03 PM
05/13/16 06:03 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
By the looks of the seat brackets, the doghouse cover isn't the only thing that won't fit with some major modifications, add seat brackets, floor pan, throttle and trans shift linkage, exhaust and cooling system for starters. The A100s were designed for slant 6 motors, when the added a 318, things got real crowded. An RB is almost 2x the width of the slant 6, at the exhaust manifold location, which happens to line up with the A100 floor pan.
Probably the main reason why the Little Red Wagon had its 426 mounted in the box. Less space limitations. Gene
Re: A100 big block?
[Re: kams]
#2073265
05/14/16 02:29 PM
05/14/16 02:29 PM
BloFish
On the run…
That's a big piece of cake!
