Re: Removing rust spots on primer
[Re: xyxxjx]
#2072228
05/12/16 08:36 PM
05/12/16 08:36 PM
Posts: 4,923 new berlin wisconsin
Mr T2U
strip all of your primer off then use a high quality epoxy primer, like PPG DP epoxy primer.
perception is 90% of reality
[Re: xyxxjx]
#2072314
05/12/16 10:57 PM
05/12/16 10:57 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Blast, treat and recoat, then seal.
Careful, your character's showing!
[Re: mopar346]
#2072330
05/12/16 11:16 PM
05/12/16 11:16 PM
Posts: 206 Los Angeles CA
xyxxjx
Los Angeles CA
Couldn't I use some of that picklex 20 rust converter or something similar? I should say I'm in an apartment building and have limited tools, no air tools.
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far.
Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be.
Don't protect a feminist when the collapse comes!
[Re: xyxxjx]
#2072855
05/13/16 08:15 PM
05/13/16 08:15 PM
xyxxjx
Los Angeles CA
Are you sure the rust is from underneath? The mechanic who worked on the car grinded down the whole roof to bare metal and put this primer on just last year.
[Re: xyxxjx]
#2073053
05/14/16 01:44 AM
05/14/16 01:44 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Primer is porous and will not seal out moisture, so water or even humidity will soak through the primer and start the rust . What you see is where it is the worst , if you look closer you will see that it is all over the primed area. The primer will have to be removed down to bare metal. The rust will have to be removed probably chemically , I wouldn't recommend blasting on a roof. Then re-prime and paint
[Re: ahy]
#2074743
05/16/16 09:45 PM
05/16/16 09:45 PM
xyxxjx
Los Angeles CA
The rust has gotten under the primer... hopefully the primer is thin! With limited tools, I'd suggest hand sand it thoroughly. 120 grit would be OK. Then shoot it with red Rustoleum rust stop spray bomb primer.
If you want to smooth it, shoot it with a couple of coats of Rustoleum auto primer and sand with 220 when well dry. It may need another coat of primer at that point. Hit it again with primer and sand lightly with 220 before the finish coat.
Do you mean rust oleum stops rust? Why red?
[Re: ahy]
#2074937
05/17/16 03:37 AM
05/17/16 03:37 AM
xyxxjx
Los Angeles CA
Rustoleum primer seals up and helps stop or slow rust. I have found it to be quite effective. The red primer in a paint can or its spray bomb cousin is specifically formulated to stop rust... more so than other Rustoleum products used as primer. Clean well and remove any loose paint or loose rust then shoot it. Rustoleum primer plus a top coat of some type should hold it for several years at least. Huge improvement over what you have and doable without a shop or big budget.
Is this the one you are refering to? https://www.rustoleum.com/product-catalog/consumer-brands/stops-rust/automotive-primer-spray
[Re: rowin4]
#2074945
05/17/16 04:58 AM
05/17/16 04:58 AM
Posts: 704 USA
rftroy
USA
Primer is porous and will not seal out moisture, so water or even humidity will soak through the primer and start the rust . What you see is where it is the worst , if you look closer you will see that it is all over the primed area. The primer will have to be removed down to bare metal. The rust will have to be removed probably chemically , I wouldn't recommend blasting on a roof. Then re-prime and paint This. Spot on. No alternative. Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: rftroy]
#2075277
05/17/16 06:48 PM
05/17/16 06:48 PM
xyxxjx
Los Angeles CA
Primer is porous and will not seal out moisture, so water or even humidity will soak through the primer and start the rust . What you see is where it is the worst , if you look closer you will see that it is all over the primed area. The primer will have to be removed down to bare metal. The rust will have to be removed probably chemically , I wouldn't recommend blasting on a roof. Then re-prime and paint This. Spot on. No alternative. Robert What specific chemical would you use to treat the rust?
[Re: xyxxjx]
#2075301
05/17/16 07:46 PM
05/17/16 07:46 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Primer is porous and will not seal out moisture, so water or even humidity will soak through the primer and start the rust . What you see is where it is the worst , if you look closer you will see that it is all over the primed area. The primer will have to be removed down to bare metal. The rust will have to be removed probably chemically , I wouldn't recommend blasting on a roof. Then re-prime and paint This. Spot on. No alternative. Robert What specific chemical would you use to treat the rust? He's right. I'd do this and follow up the sanding to bare metal with Rust-ese (it's organic), then wax and oil remover, then etching primer, scuff it and shoot high-fill primer in case you want to paint and not vinyl the thing. Then paint. and I'd pull the bright trim too! Chances are they didn't shoot paint under the trim and this is where rust loves to grow. Rust is not a game, son.
I’m listening.
[Re: Big Bad Bee]
#2075326
05/17/16 08:31 PM
05/17/16 08:31 PM
Posts: 7,664 IN
ahy
IN
This one is best for the first coat or two: "Rusty Metal Primer. The automotive primer in red or grey over the rusty metal primer would be optional to help smooth it. The auto primer sands better. If you use Rustoleum best to observe label directions on re-coat time. Usually it will say "re-coat within 2 hours or wait 48 hours". I usually apply the primer in two coats about 10 minutes apart, wait a half hour or so to let it set up then apply the finish coat. If you re-coat between 2 hours and 48 hours it may wrinkle or lift. https://www.rustoleum.com/product-catalog/consumer-brands/stops-rust/rusty-metal-primer-spray/
[Re: xyxxjx]
#2075372
05/17/16 09:34 PM
05/17/16 09:34 PM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Are you sure the rust is from underneath? Hmmm, let's See ... under the primer you have metal. On top of the primer you have ... nothing. Yeah, I`m pretty sure its from underneath !!
[Re: Stanton]
#2075500
05/18/16 12:47 AM
05/18/16 12:47 AM
xyxxjx
Los Angeles CA
Are you sure the rust is from underneath? Hmmm, let's See ... under the primer you have metal. On top of the primer you have ... nothing. Yeah, I`m pretty sure its from underneath !! I sanded down a small area that had rust on the primer. The rust disappears half way through the primer, there's no rust on the metal. But will sand down anyway to be sure.
