new E BODY speedometer #2071694
05/11/16 09:40 PM
05/11/16 09:40 PM
Virginia Beach, VA
O
Old School Offline OP
O
Virginia Beach, VA
both of my 70 cudas need the speedo rebuilt. has anybody tried the brand new ones that are available? wondering if the new ones would be better....or just rebuild mine.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: new E BODY speedometer [Re: Old School] #2071873
05/12/16 02:16 AM
05/12/16 02:16 AM
what is (are) the issues with yours?
Re: new E BODY speedometer [Re: RapidRobert] #2071933
05/12/16 10:15 AM
05/12/16 10:15 AM
Virginia Beach, VA
O
O
Virginia Beach, VA
They are basically wore out. The needle bounces around and is not accurate one of them the needle is broken off from it bouncing.
Re: new E BODY speedometer [Re: Old School] #2072004
05/12/16 01:03 PM
05/12/16 01:03 PM
is it possible that the inner cable is catching/releasing inside the outer cable sheath which up top is making the needle jump & causing the issues? EDIT I'd either in the car or on the bench rig up a short inner "square" cable to connect the two & run it with a drill & see how it acts
