Re: Aluminium small block is in car, running and driving
[Re: R3DART]
#2070589
05/10/16 08:02 AM
05/10/16 08:02 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Any guess what the Hp potential of your motor is? Drag only? Gotta love it! The only thing I can guaranty is if you stick the tires you WILL need wheelie bars!!
[Re: gregsdart]
#2070673
05/10/16 11:30 AM
05/10/16 11:30 AM
Posts: 205 Edmonton Alberta, Canada
R3DART
Any guess what the Hp potential of your motor is? Drag only? Gotta love it! The only thing I can guaranty is if you stick the tires you WILL need wheelie bars!! Greg; my goal with the build was to have a street/strip car that was able to break into the nines here in Edmonton at 2100 ft. The parameters I set for the car were as follows: -Small block -pump fuel -no power adder I have it booked for a chassis dyno session on the 20th of May. We did have the engine on the dyno, but only pulled to 7000 (not sure why, I wasn't there) but it was still gaining when they stopped pulling. I really don't want to start spouting numbers because they seem high to me compared to what I have seen on here in the past with simular combinations. Dyno numbers always seems to turn threads the wrong way!!! But like I say, will have it on the chassis dyno next week, and hopefully at the track the following weekend. You guys have any guesses at power based on what you see/hear?
[Re: R3DART]
#2070729
05/10/16 12:41 PM
05/10/16 12:41 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Depending on the cam it should threaten 700 pretty easily. If it makes that, at your weight should be able to run 9.40's-50's
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: R3DART]
#2070749
05/10/16 01:00 PM
05/10/16 01:00 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Where will you be having it dynoed at? Have some buddies up in Edmonton and just curious.
[Re: R3DART]
#2070759
05/10/16 01:12 PM
05/10/16 01:12 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Amen, that's the main reasons I didn't post the dyno numbers from my 434. after the converter is back and the fine tuning is done if it runs close to what it's supposed to I'll probably post them. Mine doesn't sound a wicked as yours does, man that thing sounds good.
[Re: Al_Alguire]
#2070815
05/10/16 02:54 PM
05/10/16 02:54 PM
R3DART
Where will you be having it dynoed at? Have some buddies up in Edmonton and just curious. [quote=Al_Alguire]Where will you be having it dynoed at? CCMR out of Spruce Grove Ab. The town is about 15 minutes west of Edmonton.
[Re: R3DART]
#2070986
05/10/16 08:04 PM
05/10/16 08:04 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
Who is your engine builder?
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
[Re: Brian Hafliger]
#2071001
05/10/16 08:22 PM
05/10/16 08:22 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
Do you have any pics of the build, and the block while assembling? Hey Brian, we have some pictures, I will have to go digging. There were a lot of weird issues with it. oil pump port was in the wrong spot on the rear cap, not enough room for the counterweights to swing in the block (radius of the casting was too big) almost zero drain back, which is nice if you are running a dry sump, but for this we drilled the block similar to a dart little M SBC block, along with drilling through the enclosed cam tunnel, lifter bores were all over the place and needed to be bushed, also, the lifter bores were too high in the block, and the lifters came too far out the bottom of the block. There was more issues, but that is what I can think of off the top of my head. Thousands of dollars in the machine shop. I think they are better now though from what we seen on that 420ci someone else built on here which would have been a production block, where as this one was apparently the prototype block. -Kenny
[Re: R3DART]
#2071010
05/10/16 08:36 PM
05/10/16 08:36 PM
StrokerAspen
Alberta Canada
We have an old manual engine dyno. The start and flywheel assembly we have for a small block dodge is ancient and it is scary to think of taking it over 7000rpm. LOL. Also, if the number seem high, again it is a manual dyno, we do not accelerate the engine through a range, it is brought to an rpm, and held there. So it is brake HP, not accelerated HP. Hopefully this helps! It more gives us an idea of what it is going to do in the car, but more so check for issues, and do break in. It worked well on this one. LOL. -Kenny -Kenny
[Re: StrokerAspen]
#2071034
05/10/16 09:19 PM
05/10/16 09:19 PM
R3DART
We have an old manual engine dyno. The start and flywheel assembly we have for a small block dodge is ancient and it is scary to think of taking it over 7000rpm. LOL. Also, if the number seem high, again it is a manual dyno, we do not accelerate the engine through a range, it is brought to an rpm, and held there. So it is brake HP, not accelerated HP. Hopefully this helps! It more gives us an idea of what it is going to do in the car, but more so check for issues, and do break in. It worked well on this one. LOL. -Kenny -Kenny Thanks Kenny! I knew there was a reason (for stopping the pull) just not what it was!! When I mention that the numbers seem high, it's really just me yacking. I really don't have much to compare it to other than what I read on here. I have to be careful what all I say cause I have nothing to back it up with yet!! I have to say, feels pretty good to be this close. Insured it today, will be registered tomorrow. Pretty pumped. She has been a long old haul, so thanks to Wayne and Kenny Joss for your perseverance on this deal.
[Re: R3DART]
#2071038
05/10/16 09:23 PM
05/10/16 09:23 PM
B3422W5
Portage,michigan
How come it was built to only 12 to 1 compression? Just curious That is leaving some power on the table.
[Re: B3422W5]
#2071047
05/10/16 09:39 PM
05/10/16 09:39 PM
justinp61
W. Kentucky
How come it was built to only 12 to 1 compression? Just curious That is leaving some power on the table. I think it's running pump gas.
[Re: B3422W5]
#2071048
05/10/16 09:41 PM
05/10/16 09:41 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I ask because I'm talking to him now about an aluminum block deal....I just don't want to run a std. block if I don't have to but I also don't need a year long project in a block! Thank you!! Brian
Brian Hafliger
[Re: justinp61]
#2071053
05/10/16 09:44 PM
05/10/16 09:44 PM
R3DART
How come it was built to only 12 to 1 compression? Just curious That is leaving some power on the table. I think it's running pump gas. I believe it's actually 12.54-1 (according to my dyno sheet anyway!) and it is a pump gas deal. The family truxter!!!
[Re: R3DART]
#2071094
05/10/16 10:36 PM
05/10/16 10:36 PM
StrokerAspen
Alberta Canada
How come it was built to only 12 to 1 compression? Just curious That is leaving some power on the table. I think it's running pump gas. I believe it's actually 12.54-1 (according to my dyno sheet anyway!) and it is a pump gas deal. The family truxter!!! Yes, it was because of pump gas, and just staying on the cautious side. 12.5:1 will be safe with that cam/stroke/rod etc. on the fuel we can readily get up here. I ask because I'm talking to him now about an aluminum block deal....I just don't want to run a std. block if I don't have to but I also don't need a year long project in a block! Thank you!! Brian Brian, I think it is worth looking into doing, from the sounds of it, they are coming around. Maybe I will give you a call later this week to have a quick chat about the block. -Kenny
[Re: StrokerAspen]
#2071120
05/10/16 11:15 PM
05/10/16 11:15 PM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
This is awesome news and cant wait to see what it runs!!
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
