So I have a 7T 440 EHP in my Charger, what is it really?
#2070906
05/10/16 06:03 PM
05/10/16 06:03 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I think I know but during a conversation today I began to question myself and then I tried to look something up and I ran across conflicting info including lean burn so I thought I would ask here before I stated what I thought it was.
Thanks in advance, Kevin
Careful, your character's showing!
Re: So I have a 7T 440 EHP in my Charger, what is it really?
[Re: mopar346]
#2070920
05/10/16 06:30 PM
05/10/16 06:30 PM
mopar346
Thank you Dan, that is what I have believed for a long time but never really cared since a 77 HP engine is still pretty weak, especially a 40 year old one.
Probably on the partial VIN but not sure when I will be under it to get it. What was the HP rating on it from the factory and was it mainly a cam difference as in earlier engine.
[Re: mopar346]
#2070946
05/10/16 07:10 PM
05/10/16 07:10 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
If it is a police car version 255 HP. If not it might be as low as 225. Keep in mind in 72 they went to NET ratings so that alone dropped the numbers a ton. A "good" year 375 HP 440 was probably only like 325 or something NET.
Was not just a cam change, depending on head casting it was worse heads, smaller valves. Lower compression. Worse cam. Worse intake and exhaust manifolds. By worse I mean redesigned for emissions rather than performance...
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
[Re: mopar346]
#2070951
05/10/16 07:18 PM
05/10/16 07:18 PM
mopar346
I understand significant difference between a performance year engine and the mid-late smogger engine, I was more referring to same year engine difference between the low 225 and the "higher" 255 horse engine was mainly cam.
I think the change in rating was from reading it with all the accessories verses a bare engine or something like that.
[Re: 451Mopar]
#2071817
05/12/16 12:29 AM
05/12/16 12:29 AM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Really not much difference in the heads, but relay low compression pistons and a mild cam. I don't know about the intake or exhausts. They can be built up just like any other 440. I have a book around here somewhere that has the cam specs and emissions info and the late HP cam was almost identical to the earlier ones, just a little MORE overlap for its natural EGR effect. The late exhaust manifolds are huge compared to the earlier HP manifolds and probably flow more but they are heavy. I think the lean mixtures and low spark advance are real killers in addition to the lowered compression. I had a '77 440 hp many years ago and it ran fine with some tuning.
