Traction Bar or Adjustable Pinion Snubber?? #2070170
05/09/16 04:34 PM
05/09/16 04:34 PM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
I got some wheel hop on my 69RR. Any suggestion which way I should go Traction Bars or Adjustable Pinion Snubber ??
Thanks Tom C.
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: TOMRR] #2070229
05/09/16 06:20 PM
05/09/16 06:20 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Neither, make or buy some clamps for your front spring segments. Id suggest two on the passenger side front, one on the driver side front. And also maybe one each on the rear of the axel on both sides.
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: Sport440] #2070252
05/09/16 06:57 PM
05/09/16 06:57 PM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
Thanks for the Reply, Not sure what you mean by Clamps !!!
Tom C.
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: TOMRR] #2070271
05/09/16 07:35 PM
05/09/16 07:35 PM
AndyF Online content
AndyF  Online Content
Never ever use traction bars on a Mopar!
What springs are on there now? If they are old original springs then perhaps an upgrade is in order. Hemi springs would be a good start or Super Stock springs if you're serious about drag racing.
The pinion snubber may or may not be something to use, opinions vary. Clamping the front leaves together like Sport says is a cheap and easy tuning trick.
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: TOMRR] #2070272
05/09/16 07:40 PM
05/09/16 07:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Spring clamps
http://www.manciniracing.com/caspcl.html
Similar to what the factory used.
Don't be the exception.
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: Supercuda] #2070275
05/09/16 07:44 PM
05/09/16 07:44 PM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
Caltracs can be used successfully.
1972 Road Runner
1988 Shelby CSX-T
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: Supercuda] #2070415
05/09/16 11:12 PM
05/09/16 11:12 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By Supercuda
Spring clamps
These are not the type of clamps im referring to. The clamps are more like two flat steel bars tightend by bolts that are just beyond the width of the springs. Much more clamping power then these clamps shown in the link.
IMO, Clamps or different springs are your fix.
1.El cheapo, clamps. And they can work.
2. More bucs, SS springs
3. Caltracs.
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: Sport440] #2070473
05/10/16 12:37 AM
05/10/16 12:37 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
All I use is the Super Stock leaf springs. No pinion snubber and I made sure the front part of the springs are clamped. My 63 hooks fine like that on 9" radial slicks. I have seen alot of guys run pinion snubber which to me can be kind of a bandaid to help hook if the springs are worn and not working. My car hooked no better or went any faster with a pinion snubber so I dont use it since I run the 3400 lb SS springs. I have not seen many Mopars ever use traction bars as they usually dont work so good on Mopars and thats why Mopar came out with the pinion snubber. But if your SS springs work right you wont need any additional parts on it just the SS springs. Now Cal Tracs work great but they work best using the mono spring that comes with them from what I hear. Ron
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: TOMRR] #2070560
05/10/16 02:44 AM
05/10/16 02:44 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Caltracs are noisy and much too harsh on a street driven car. They work phenomenally on a smooth race track. Pinion snubbers, when properly adjusted, are way to harsh on a street driven vehicle. I learned this from several decades of experience.
I run slapper bars on my '68 Barracuda with two passenger side Super Stock springs and a 1" lowering block. I had to modify them so they were adjusted properly.
I know, I know, they don't work on Mopars. LOL
I guess the reason I just beat a Hellcat in a flag drop drag race to win the Willow Springs Drags at Spring Fling was my GM 200R4 transmission. My car only had 410 hp at the time too.
The bottom line is they work awesome, ride only slightly stiffer and if you paint them satin black, most people will not tell you how they don't work.
Even Bob Tarozzi, the designer of the Super Stock Springs signed off the set-up of my car. He said they didn't use them because of weight. A pinion snubber is lighter and works great on a smooth track.
IMG_1005 (Large).JPGIMG_0985 (Large).JPGIMG_0979 (Large).JPGJohnRace2 (Large).jpg
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: TOMRR] #2070566
05/10/16 03:13 AM
05/10/16 03:13 AM
Wheel hop is really hard on all of the drive train parts, driveshaft, tranny, rear end, U joints axles and so on, not good tsk I would replace the existing leaf springs with better ones, what kind of driving do you do mainly to induce wheel hop? Is it a 4 speed or automatic?
Pinion snubbers where intorduce on Mopars in 1957 when they lowred the cars closer to the ground to prevent the pinion U joint from hitting the drive line tunnel, not for traction scope work
Fix the problem, don't bandaid it tsk
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: Cab_Burge] #2070599
05/10/16 08:34 AM
05/10/16 08:34 AM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
My RR is a 4-Speed with 1970 HP 440 That Dyno at 425 HP and 500 ft.lb torque. It has new hemi Springs on it and what about clamps ??/I do not drag the car and but once in a while would like to spin the tires
Mostly just long drives
Thanks Tom C.
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: Cab_Burge] #2070602
05/10/16 08:36 AM
05/10/16 08:36 AM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
Thanks Tom C.
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: jbc426] #2070764
05/10/16 01:20 PM
05/10/16 01:20 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
I'd have to agree here. I added a Pinion Snubber to my 440 4-spd car, and it launched awesome. However, in normal driving it was a major pain. I took it off. I was and still am running factory 440 replacement springs in the car. But, if I wanted to race more, would definitely consider SS springs.
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: TOMRR] #2070787
05/10/16 02:14 PM
05/10/16 02:14 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Thanks Tom C.
Your car looks kind of high in the back for stock hemi springs. Does it perhaps have airshocks on it? If not then are the shocks long enough? If they are airshocks or if the shocks are topping out then you will always have wheel hop.
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: Dixie] #2070794
05/10/16 02:22 PM
05/10/16 02:22 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I'd like to see someone like AndyF develop a retractable pinion snubber, so it can be deployed or retracted on the fly from inside the car. Something simple and robust that locks in either the extended or retracted position with the flip of a switch. It would need to have some range of adjustability, and when retracted stays out of the path of the suspension movement.
It seems like even a cable operated knee-like lever inside the snubber body would work.
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: TOMRR] #2070797
05/10/16 02:27 PM
05/10/16 02:27 PM
On your deal buy a good set of leaf springs designed and intended to be used like you want scope I'm not sure if Mopar still offers a set for a 1964 to 1970 B body 4 speed car for all around high performance drinving like you want to do confused scope I bought a set of the Mopar S.S. road race type leaf springs for my 1966 Coronet, they are the shorter front half length like the A bodys are so the front spring hangars would need to be replaced to keep the rear end in the stock location if you want to do that. I didn't use them as I moved the leaf springs into the rear sub frames and moved the rear end forward two inches, which required reshaping the front fender openings devil whistling
I'm sure your leaf springes are worn out so replacing them will help the car a bunch, if you want to try a new set first before adding clamps do that thumbs If you want to add the clamps later I use 1/4 thick by 1.0 inch wide flat stock steel and drill 3/8 holes in them on each side and use 3/8 bolts of the proper length for each clamp, I place them on the front half of the spring in every where I can (the tire bulge will, may, hinder using one on each side near the tire bulge scope) on the front of each shorter leaf springs to clamp it to the main leaf. Do it with the weight of the car on them, don't jack it up on jack stands with the rear end hanging down tsk You can jack it up and put jack stands under the rear end axle tubes and under the front suspension so it has the weight on the suspension to do that to be able to get under it to work on the car thumbs
Let us know what you do and the results thumbs
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: GomangoCuda] #2071023
05/10/16 08:54 PM
05/10/16 08:54 PM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
Thanks Tom C.
No air shocks but I got new shocks from Napa, Any suggestion on a type of shocks to get ??
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: TOMRR] #2071163
05/10/16 11:59 PM
05/10/16 11:59 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Tom that is one sweet Roadrunner as I love how it looks and sits. Thats a car to be very proud off. up Ron
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: TOMRR] #2071231
05/11/16 01:19 AM
05/11/16 01:19 AM
GomangoCuda Offline
GomangoCuda  Offline
Longer and stiffer. I bet they are way too short. Aftermarket HD shocks often are.
Re: Traction Bar or Adjustable Pinion Snubber?? [Re: TOMRR] #2072399
05/13/16 01:05 AM
05/13/16 01:05 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Seems like many options have been laid out for you. There are many ways to resolve this. We can all agree your current leaf springs are too weak. Stiff shocks help too.
The solution with the least drawbacks is a pair of Super Stock springs and a pair of stiff shocks.
A pinion snubber remove ALL suspension travel on the street. As for the clamps, leafs want to slide. You need to clamp these hard enough to force them not to because they want to. When they do slide, the clamps wiĺl hold your car down after suspension compression and hold the car up after suspension compression.
