fuel pressure ? #2070540
05/10/16 02:08 AM
05/10/16 02:08 AM
canada
fast414 Offline OP
fast414  Offline OP
canada
When I start my car it's has 6 psi and the longer it runs the fuel psi goes to 3 psi.....and when I'm on the throttle holding at 2500rpm.....the rpm starts dropping without me moving my foot at all .....Carb adjust ment ??????
Re: fuel pressure ? [Re: fast414] #2070563
05/10/16 02:54 AM
05/10/16 02:54 AM
what eng. what fuel pump. E10 or not fuel. recent issue. recent changes/adjustments. complete details needed. not a carb adjustment, it ain't being fed properly (for some reason)
Re: fuel pressure ? [Re: fast414] #2070690
05/10/16 11:55 AM
05/10/16 11:55 AM
moparx Offline
moparx  Offline
does it run ok at the pressures you are reporting, or does it start to act up ?
beer
Re: fuel pressure ? [Re: fast414] #2070700
05/10/16 12:07 PM
05/10/16 12:07 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
For a carb, it should be around 6-7psi. Fuel pump is probably worn out. If it is mechanical, lookout for gas in the oil if the diaphragm is leaking.
Craig
