Tranny leak at the pan #2069942
05/09/16 10:29 AM
05/09/16 10:29 AM
Canada
Dons Dart Offline OP
Canada
Ok, a buddy put a shift kit in my 904and he knows what hes doing great around cars and used the rubber gasket for the pan.The pan is flat,but its leaking,i can see right were its leaking 1 spot.I like the cork gasket,is there a sealer that is transmission fluid friendly to use with the cork.Thanks.
Re: Tranny leak at the pan [Re: Dons Dart] #2069947
05/09/16 10:35 AM
05/09/16 10:35 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
You might want to try the newer mopar gasket 4295875AC. They seem to work pretty well. I never liked cork to be honest.
Re: Tranny leak at the pan [Re: Dons Dart] #2070467
05/10/16 12:29 AM
05/10/16 12:29 AM
tucson az
frank Offline
frank  Offline
tucson az
I used the newer factory gasket for my 727 and it works
Re: Tranny leak at the pan [Re: frank] #2070636
05/10/16 10:18 AM
05/10/16 10:18 AM
Canada
Canada
Is that the 1 mopar4ever used.
Re: Tranny leak at the pan [Re: Dons Dart] #2070641
05/10/16 10:20 AM
05/10/16 10:20 AM
md
md
Same type part but 727 uses a different part number.
Re: Tranny leak at the pan [Re: mopars4ever] #2070809
05/10/16 02:45 PM
05/10/16 02:45 PM
Canada
Canada
Is that the same part # for my 904
Re: Tranny leak at the pan [Re: Dons Dart] #2070891
05/10/16 05:32 PM
05/10/16 05:32 PM
md
md
4295875AC 904
Re: Tranny leak at the pan [Re: mopars4ever] #2071322
05/11/16 10:07 AM
05/11/16 10:07 AM
Canada
Canada
Thank you sir.
Re: Tranny leak at the pan [Re: Dons Dart] #2071696
05/11/16 09:41 PM
05/11/16 09:41 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
You mentioned the pan was straight. The flange on steel pans can distort from uneven tightening. Over-tightening the bolts will result in the flange pushing in around the bolt, causing an uneven surface. It extremely important that the flange be flat. The gasket recommended by mopar4ever is as good as they get. I gave up on the steel pans years ago and went with the cast aluminum pans but they're expensive. Whether it's worth it or not depends on your frustration level.
Re: Tranny leak at the pan [Re: Dons Dart] #2071700
05/11/16 09:46 PM
05/11/16 09:46 PM
md
md
One thing you can check is to see if sealer or any other crap is in the bolts holes. Sometimes the bolts feel tight but they are really bottoming out on the sealer. Ask me how I know. blush
Re: Tranny leak at the pan [Re: Dons Dart] #2071732
05/11/16 10:45 PM
05/11/16 10:45 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
What is the 727 gasket part number?
Re: Tranny leak at the pan [Re: Dons Dart] #2071786
05/11/16 11:59 PM
05/11/16 11:59 PM
Washington/Las Vegas
1971 Gran Coupe Offline
Same thing happened to a friend and he was at a total loss as what to do. He shoewed me the pan, and it was very evident it had been over tightened and the distortion from the bolts and washers. I told him it could be an easy fix and used a dolly and hammer and worked the pan flange flat and he reinstalled and it does not leak a drop. Maybe yours will be this easy. beer
Re: Tranny leak at the pan [Re: Dons Dart] #2071802
05/12/16 12:16 AM
05/12/16 12:16 AM
md
md
2464324AC 727
Re: Tranny leak at the pan [Re: Dons Dart] #2071929
05/12/16 10:01 AM
05/12/16 10:01 AM
Canada
Canada
Well I got the gasket,will change it and post what the out come is.Thanks for all the help.
Re: Tranny leak at the pan [Re: Dons Dart] #2071974
05/12/16 11:55 AM
05/12/16 11:55 AM
md
md
Make sure all the bolt holes are cleaned out. I used a pick.
Re: Tranny leak at the pan [Re: mopars4ever] #2075773
05/18/16 12:42 PM
05/18/16 12:42 PM
Canada
Canada
Sorry for taking long to post back,that gasket work purrfect thanks.
