Idle Solenoid Woes #2069763
05/08/16 11:54 PM
05/08/16 11:54 PM
Ohio in the USA
O
Omni Source 1 Offline OP
O
Ohio in the USA
Good Day All
I have a '68 Super Bee with a six pack. My problem is with the idle quality. When it is started (cold) it will idle at approx 600RPM . As it warms up the idle will increase to approx. 1400-1500. It will not idle down. The solenoid will either chatter or not work at all. It is wired from the ballast resistor (continuity is good). A quarter turn on the curb idle screw will drop the idle to 7-800 RPM.
I tried to jumper the solenoid from the battery with no result. I think the solenoid is FUBAR.
However, this is not consistent. Sometimes it will idle great, then the next time you accelerate the idle speed will jump back up.
I really don't understand this.
Any/All responses are welcomed.
Omni
Re: Idle Solenoid Woes [Re: Omni Source 1] #2069902
05/09/16 06:45 AM
05/09/16 06:45 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Is that a reproduction solenoid? If it is, that's most likely your problem. Unplug it and set the idle with the idle screw only and see if that doesn't take care of the problem. I have some NOS solenoids if you need one.
Re: Idle Solenoid Woes [Re: Omni Source 1] #2070714
05/10/16 12:27 PM
05/10/16 12:27 PM
Chicago
PurpleBeeper Offline
Chicago
Another possibility is that your carbs and/or return linkage is hanging up. Maybe try a heavy dose of carburetor cleaner on all the pivot points and "feel" if there is something getting stuck. You might check your return spring too and/or add a second return spring just to be sure the carbs pull shut when you take your foot off the gas.
Additionally, it could be that your carbs aren't tuned just right. What I mean by that is maybe the idle is set a little high to keep the car running when cold (choke not working exactly right) and once it warms up, that carb(s) setting makes it idle too high?
The idle solenoid will definitely open with the base grounded & a hot wire run to the spade connector. Hey, maybe your ground at the intake isn't all that good? If it's a '69 aluminum intake, maybe you could run an extra ground wire to the solenoid base? Just thinking outside the box here.
Another possibility I can think of is that sometimes people adjust the return linkage to leave the outboard carbs cracked slightly open to help the car idle. I tried this on my car and I got the same symptoms as you're reporting.....sometimes the outboards close all the way & it idles down while other times they stay open just a crack and it wouldn't idle down.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
