Re: 360/904 [Re: rbstroker] #206977
01/30/09 09:31 AM
01/30/09 09:31 AM
scratchnfotraction Offline
well then its just gotta be my crap luck with a 904 then
Re: 360/904 [Re: scratchnfotraction] #206978
01/30/09 12:51 PM
01/30/09 12:51 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
it may just be that you have old worn out junkyard transmissions, next one you get, rebuild it properly using good quality parts (i have used transtar kits), a workshopmanual a few nights being carefull so its all right and a Transo TF2 shiftkit and you will have a very nice shifting 904īthat will last along time as long as you dont do something stupid or just make way to much power
my 904 holds up just fine behind a pretty strong running solidrollercamed highcompression 340 in a duster
Re: 360/904 [Re: 1Fast340] #206979
01/31/09 12:02 AM
01/31/09 12:02 AM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
I've got over 250 passes on my 904 behind a 360. The car runs in the 11's. Never had a problem. I changed the fluid once when I put a new converter in it, otherwise I never touched it.
Raul
Re: 360/904 [Re: Aspen7695] #206980
01/31/09 12:07 AM
01/31/09 12:07 AM
We even got TBF's 904 up & flying after he snapped the input shaft.
Re: 360/904 [Re: RapidRobert] #206981
01/31/09 09:45 AM
01/31/09 09:45 AM
West Tennessee
rbstroker Offline OP
West Tennessee
I am using an early 904 with front and rear pumps and cable shift. Don't know if the input is a weak link or not. I believe that I will get the deep pan and pickup though. Going to pick up the 360 tomorrow. I put a lot of dollars into the 273 and I am not happy at all. Experts all predicted that. Live and learn I guess.
This is the land of the free because of the brave
Re: 360/904 [Re: scratchnfotraction] #206982
02/01/09 02:11 PM
02/01/09 02:11 PM
5thAve Offline
5thAve  Offline
Its not crap luck its just the way 904s are.
