Page 1 of 8 1 2 3 4 5 6 7 8
Fast leaf spring guys inside #2069360
05/08/16 02:36 PM
05/08/16 02:36 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
Im looking for pointers what have you guys done to get your 60ft down. I'm running caltracs and A body mono leaf ,,,sliders. I'm going to try a stiffer rear segment spring to hopefully eliminate some of the rear end rotation..is it possible to get a sub-1.20 60 foot in N/A out of this setup
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Fast leaf spring guys inside [Re: WHITEDART] #2069376
05/08/16 03:14 PM
05/08/16 03:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Wrong thing to do... its your shocks
wave
Re: Fast leaf spring guys inside [Re: WHITEDART] #2069426
05/08/16 04:53 PM
05/08/16 04:53 PM
muskegon MI
v cummins Offline
v cummins  Offline
muskegon MI
Yes you are on the right track.
In top stock a buddy of mine Bill Parris would go 1.19 60 foot in a 9.80 car.
fr
end
Re: Fast leaf spring guys inside [Re: MR_P_BODY] #2069457
05/08/16 06:02 PM
05/08/16 06:02 PM
bean town ....Ca
W
W
bean town ....Ca
wave
at the release of the trans brake the wheelie bar rotates 9 inches. Which at that point is too low to the ground I cannot raise the wheelie bar anymore so hopefully eliminating some of the rotation will stop it from unloading the tire when it plants the wheelie bar
Re: Fast leaf spring guys inside [Re: WHITEDART] #2069466
05/08/16 06:15 PM
05/08/16 06:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
The spring is there to hold up the car.. you dont
want 2 opposing forces on the spring.. the shock
controls rise .. you might have to move the wheelie
bars up higher
wave
Re: Fast leaf spring guys inside [Re: WHITEDART] #2069469
05/08/16 06:20 PM
05/08/16 06:20 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
John makes a wheelie bar that acts as a lever and plants the tires harder when it hits.
Real Men shift for themselves
Re: Fast leaf spring guys inside [Re: WHITEDART] #2069482
05/08/16 06:41 PM
05/08/16 06:41 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I'm not that fast with my 3900 lb brick,but I hope to start tuning my suspension and my high 1.4 down some.Do you guys put much preload in??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Fast leaf spring guys inside [Re: MR_P_BODY] #2069486
05/08/16 06:46 PM
05/08/16 06:46 PM
muskegon MI
v cummins Offline
v cummins  Offline
muskegon MI
wave
bars up higher
wave
The shock controls rise but if you are at the limit at the shock the spring must get stiffer.
look at stoping rear end rotating
Re: Fast leaf spring guys inside [Re: v cummins] #2069490
05/08/16 06:55 PM
05/08/16 06:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
bars up higher
wave
If your at the limit of the shock you have the
wrong shocks.. period... if you put a stronger
rear segment on it that pulls down on the body..
which is really lifting the axle.. opposite of
what the front segment does
wave
Re: Fast leaf spring guys inside [Re: v cummins] #2069546
05/08/16 08:04 PM
05/08/16 08:04 PM
bean town ....Ca
W
W
bean town ....Ca
wave
bars up higher
wave
the wheelie bars are up against the floor of the trunk so going higher is not an option the shock does not control the rear end from rotating... I think you missed the question MR,P are you don't understand what I'm asking. This is a common practice with fast leaf spring cars I was told by caltracs
Re: Fast leaf spring guys inside [Re: WHITEDART] #2069555
05/08/16 08:18 PM
05/08/16 08:18 PM
muskegon MI
v cummins Offline
v cummins  Offline
muskegon MI
I dont want the shocks doing all the work thay are 3' from the center of the axl
A stiffer rear seg will pull down on the shackle and we all know what that dos to the front end =get it up on the tire faster = more tire pres.= faster 60s
Re: Fast leaf spring guys inside [Re: WHITEDART] #2069559
05/08/16 08:22 PM
05/08/16 08:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Think about it.. what allow the pinion to rotate..
the body going up.. you have pretty much a solid
front segment... when the front of the pinion rolls
up that turns the rear segment down.. why do you think
they unclamp the rears... but do what ever you want
wave
Re: Fast leaf spring guys inside [Re: WHITEDART] #2069564
05/08/16 08:33 PM
05/08/16 08:33 PM
Washington
madscientist Offline
Washington
I was hoping Monte would chime in but so far nope.
The OP is in DIRE need of a double adjustable shock. Mr P is dead on. The spring only holds the car up and the shock controls the motion of the spring.
Shocks shocks shocks.
Re: Fast leaf spring guys inside [Re: madscientist] #2069568
05/08/16 08:40 PM
05/08/16 08:40 PM
bean town ....Ca
W
W
bean town ....Ca
I have Double adjustables in all four corners separation and rotation have nothing to do with one another
Re: Fast leaf spring guys inside [Re: WHITEDART] #2069572
05/08/16 08:45 PM
05/08/16 08:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You have caltracs correct.. that turns the front
pretty much solid.. the front is moving up which
allows the rotation.. if the body didnt lift you
would have about zero rotation... but then you
wouldnt be applying the pressure on the diff
wave
Re: Fast leaf spring guys inside [Re: WHITEDART] #2069573
05/08/16 08:47 PM
05/08/16 08:47 PM
SoCal
Brian Hafliger Offline
SoCal
Did you ever look into the Chucky bar at Mandellas?
Brian Hafliger
Re: Fast leaf spring guys inside [Re: WHITEDART] #2069574
05/08/16 08:47 PM
05/08/16 08:47 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
IIRC the car in question utilizes lowering blocks.... does this come into play on tuning?
Re: Fast leaf spring guys inside [Re: Brian Hafliger] #2069592
05/08/16 09:09 PM
05/08/16 09:09 PM
bean town ....Ca
W
W
bean town ....Ca
yes Phil look at the car in Las Vegas. And had the same recommendation is John Calvert stiffer rear segment and said if I didn't have contracts he would recommend the Chucky bar but being as how I had caltracs they were fine...
Re: Fast leaf spring guys inside [Re: Brian Hafliger] #2069651
05/08/16 10:10 PM
05/08/16 10:10 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Have you got a link or something?
Re: Fast leaf spring guys inside [Re: WHITEDART] #2069678
05/08/16 10:33 PM
05/08/16 10:33 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Front segment goes solid when caltracs bar rotates. Your shocks control how much it separates. I think you need better rear shocks.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
