3 speed vs 4 speed spline count #206889
01/28/09 04:39 PM
01/28/09 04:39 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
Hi Guys
looking to do a 4 speed conversion on a 65 dart It currently has a 3 speed on the column is the spline count on the 3 speed 23 also or will I have to change the clutch also will the 4 speed bolt up to the 3 speed bellhousing Car is a 273 2bbl.
Re: 3 speed vs 4 speed spline count [Re: gts1] #206890
01/28/09 05:09 PM
01/28/09 05:09 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
The spline count will be the same (23 spline).
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: 3 speed vs 4 speed spline count [Re: EWJ] #206891
01/28/09 06:04 PM
01/28/09 06:04 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I'm 99% sure the 3-speed bellhousing will not match the 4-speed's (I'm assuming an A-833 here) bolt pattern. You'll need a SB 4-speed BH.
Re: 3 speed vs 4 speed spline count [Re: gts1] #206892
01/28/09 07:50 PM
01/28/09 07:50 PM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
Check to see if the bellhousing has 2 bolt patterns. I know the 70's bellhousings would work with either 3 or 4 speed
Re: 3 speed vs 4 speed spline count [Re: sbhpcb] #206893
01/28/09 07:52 PM
01/28/09 07:52 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Same spline count, same bell housing
Re: 3 speed vs 4 speed spline count [Re: ScottSmith_Harms] #206894
01/28/09 08:01 PM
01/28/09 08:01 PM
Same spline count, but the '66 Valiant 3-speed column shift trans that I have won't bolt up to the 4-speed '66 833 bell housings I have. It probably will bolt to the later dual pattern bell housing with the 3-speed bolt pattern.
The only reason I have that trans is to pirate the screws out of it.
Re: 3 speed vs 4 speed spline count #206895
01/28/09 08:09 PM
01/28/09 08:09 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
In or around those years of 273's I've seen a castiron bell with a 3 speed bolt patern with a smaller 10" cltuth.
Re: 3 speed vs 4 speed spline count [Re: 500ciDuster] #206896
01/28/09 09:14 PM
01/28/09 09:14 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I should have added...."For 70 and up 3 speeds"
