1969 distributor finish #2067621
05/05/16 08:58 AM
05/05/16 08:58 AM
OhiO
drgordi Offline OP
drgordi  Offline OP
OhiO
Anyone have a better way to get a new natural finish on an aluminum distributor. I have tried soda blasting. That gave it a clean finish just not as clean and bright as the inside of it. I don't want to use glass or sand its to dull of a finish. Thanks in advance.
Re: 1969 distributor finish [Re: drgordi] #2067641
05/05/16 10:21 AM
05/05/16 10:21 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Try The Works Toilet Bowl Cleaner, a mild hydrochloric acid:
http://www.theworkscleans.com/index.html
Apply with tooth brush and scrub with Scotch Brite while wearing rubber gloves.
To preserve the finish apply Alodine 1001 or 1201, an aircraft coating for aluminum. 1001 is clear (invisible after it dries) and 1201 is the same except tinted slightly yellowish, but not much, simply as an indicator that the solution has been applied. I believe that Mopar aluminum alternator housing castings were coated with 1201 or similar during manufacture, and that Jim Ridge at Dixie Restorations recoats alternator restorations with 1201. I also believe Tremec transmission castings are coated with 1201.
Alodine is a hazardous product containing chromic acid, hydrofluoric acid, and potassium ferricyanide.
Re: 1969 distributor finish [Re: drgordi] #2070549
05/10/16 02:30 AM
05/10/16 02:30 AM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
Good to know. I was going to try and clean up my alternator a little bit to get that white crust off of it.
inherited a 69 roadrunner from my grand pop.
Re: 1969 distributor finish [Re: drgordi] #2071805
05/12/16 12:20 AM
05/12/16 12:20 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Great information
Re: 1969 distributor finish [Re: drgordi] #2071854
05/12/16 01:51 AM
05/12/16 01:51 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
These are aluminum pulleys that I cast and machined decades ago in a shop class. They've been stored in a garage and have dark corrosion but no white rust. In these photos they have been washed in soap and water only. Sorry, but I should have chosen lighting other than this yellowish fluorescent.
Re: 1969 distributor finish [Re: drgordi] #2071855
05/12/16 01:54 AM
05/12/16 01:54 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
These photos are after treatment with The Works toilet bowl cleaner, a mild hydrochloric acid.
Re: 1969 distributor finish [Re: drgordi] #2071857
05/12/16 01:58 AM
05/12/16 01:58 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Applying Alodine 1201.
Re: 1969 distributor finish [Re: drgordi] #2071868
05/12/16 02:11 AM
05/12/16 02:11 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Top photo: After applying the 1201 conversion coating for preservation against oxidation and white rust. The single pulley at left rear is half coated with 1201 which contains a yellow die that isn't very noticeable. The double pulley in front is still wet with the 1201. The preservation should last a few years, at least as long as you can see some yellow die. This is a good reason not to use the Alodine 1001 which has no die.
Bottom photo: Just the right half is coated with 1201. Keep in mind that the lighting is yellow fluorescent.
Re: 1969 distributor finish [Re: drgordi] #2072646
05/13/16 03:21 PM
05/13/16 03:21 PM
Greenwood Lake, NY
Greenwood Lake, NY
Wow ! I see a huge difference. Again, thanks for sharing that. I'm sure that will help me when I try to at least clean up the alternator. I see some sand marks. Did you just soak it in the Works stuff or did you use something like a brillo pad or some other kind of abrasive on it?
Re: 1969 distributor finish [Re: drgordi] #2073052
05/14/16 01:44 AM
05/14/16 01:44 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The 'sand' marks are from shaping the parts decades ago. Apply the HCl acid with a toothbrush, and you'll see some white foaming indicating that the part is being partially consumed by the acid. You can scrub the part with an acid-soaked Scotch Brite pad to see if any spots are removed that way.
Rewetting the acid a few times will continue the foaming, but you'll probably want to put a stop to the reaction after about 10 minutes by washing off with running water.
The acid will dissolve any metal pad like Brillo and probably make a big mess.
Re: 1969 distributor finish [Re: drgordi] #2073083
05/14/16 03:08 AM
05/14/16 03:08 AM
Greenwood Lake, NY
Greenwood Lake, NY
Sorry, I was thinking of that green pad that my Mom has that she uses for getting stuck on food off of the pots and pans. I misused the Brillo name.
Re: 1969 distributor finish [Re: drgordi] #2073616
05/14/16 11:53 PM
05/14/16 11:53 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
You could also use vinegar for this. It's just slower.
Re: 1969 distributor finish [Re: drgordi] #2073650
05/15/16 12:45 AM
05/15/16 12:45 AM
Greenwood Lake, NY
Greenwood Lake, NY
Did not know that either. Thanks.
