Re: 42re problem
[Re: Dabee]
#2067611
05/05/16 05:28 AM
05/05/16 05:28 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Sounds like it sets a code in the PCM when it does this which can be why it wont go into overdrive until you shut the ign off and start it again. I have run into that before that once the PCM has the right code in it related to the trans overdrive problem it wont let the overdrive work until you shut it off and then if its not a hard code and the PCM dont see it on restart it will let the overdrive work again. I would first see if it sets a trans related code in the PCM when it happens. What year and vehicle is it ? Ron
Re: 42re problem
[Re: Dabee]
#2068112
05/06/16 03:24 AM
05/06/16 03:24 AM
383man
Balt. Md
Oh so it is a three wire hall effect type sensor as its been a while for me but I just remembered the two wire sensor on them. As long as thats the factory sensor and PCM then it should work good. The thing is many year trucks I remember used the ABS sensor in the rear diff for the speedo as that info was bussed to the cluster for it to work the speedo. That sensor info in the ABS module was set as we could set the gear ratio and tire size so it sent the right info to the speedo/cluster. We also had an option for Revs per mile if it had an odd size tire on it but the sensor in the trans tail housing had nothing to do with the speedo from what I remember it only was for the output shaft speed and gov press on the 42RE. But Mopar did use a hall effect sensor in some truck trans tail housings when they had fully hydraulic gov and they were for the speedo on earlier years without electronic gov. This is definetly the electronic gov in it right ? Also a taller tire wont matter as the gov pressure is related to driveshaft/trans output shaft speed as the tire size would only effect the speedo which this sensor should have nothing to do with if this is an electronic gov from all I remember as all electronic gov trucks use the RWAL ABS as standard and used the ABS sensor in the rear for the speedo.Ron
