Re: Adding a "booster" electric fuel pump for easier starting ?
[Re: Kern Dog]
#2066811
05/03/16 10:43 PM
05/03/16 10:43 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Running an electric in series with a mechanical is no problem at all. Been recommended since the Direct Connection days.
As far as drift cars.. hate em. So no comment.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: Kern Dog]
#2066821
05/03/16 10:48 PM
05/03/16 10:48 PM
DARTH V8Я
Its a TRAP!
It is for the ricers. If I wanna 'drift' I'll give her 1/2 throttle.. e-brake need not apply.
[Re: Kern Dog]
#2067424
05/04/16 09:25 PM
05/04/16 09:25 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
[Re: Kern Dog]
#2068562
05/06/16 11:15 PM
05/06/16 11:15 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I found an electric timer relay, turn ignition on, relay turns on, 5 seconds of prime, relay turns off, turn ignition off then turn on to get it to run another 5 seconds. Put a rattle pump parallel to a check valve and you are in. Pump only runs at start up. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Kern Dog]
#2068591
05/06/16 11:58 PM
05/06/16 11:58 PM
Posts: 3,379 KY USA
mopargem
KY USA
You guys have some great ideas. I like my cars pretty much stock looking but both my RR and AAR have electric pumps (got em that way) and are always easy starts! Just turn on the key and after a few seconds pump the carb few times and they start right up. My other cars require multiple starts almost to the point the battery is done if they haven't ran in awhile. BUT the fuel pumps are very loud, so I'm liking the idea of initial usage and then let the mechanicle take over.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: Kern Dog]
#2068603
05/07/16 12:13 AM
05/07/16 12:13 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
So the purpose of even keeping the mechanical pump is for factory looks? My Charger is heavily modified and I just run an electric pump and have been for several years now. I have never thought about any reason for both.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: Kern Dog]
#2068617
05/07/16 12:32 AM
05/07/16 12:32 AM
astjp2
Utah and Alaska
I am using a mechanical pump that is supposed to be good for 2000 horsepower, Racepumps 2000, but it does not prime itself. I just don't like electrical pumps. Too many failures when I needed them. Tim
[Re: Kern Dog]
#2068780
05/07/16 11:44 AM
05/07/16 11:44 AM
Posts: 3,379 KY USA
mopargem
KY USA
I can't stand the electric pump whine, it's really loud on my RR but I do like them for quick start up. My RR still has a stock pump on it that I assume is still working also. I simply need to interrupt the electric pump with a switch I can momentarily turn on at start up instead of being on all the time. My AAR has a block off plate with no mechanicle pump but easy fix assuming the eccentric is still there. The electric pumps are both mounted near the fuel tanks and you can't even see them to retain my stock look.
