Motor location, plate and steering rack?
#206572
01/28/09 02:23 AM
01/28/09 02:23 AM
Posts: 769 Europa, Estonia
Georg
Europa, Estonia
Hi guys
Can you help me out a little. I just realized that my Charger motor sitting way more on right side from center of car. Is it normal and why is that? Is it only for steering gear? If I measured then on right side there is about 2,7" from subframe to motor side and on left side there is about 5" gap from left side on frame and motor side. So it makes about 3" motor sitting out from car center on right side. Second question is about front motor plate. Do you guys leave original motor mounts and use them with motor plate or you take them away when installing front motor plate? About steering rack. Do anyone use steering rack on he`s B-body? I really want to change old and heavy steering gear to rack. Main problem install...seems to me that oil pan causing some problems installing rack?
Outlaw Plymouth Valiant
R5/P7 Powered by Liuzzo Racing
COMP Performance Group dealer in Baltic
Premium Performance
Re: Motor location, plate and steering rack?
[Re: Georg]
#206574
01/28/09 08:34 AM
01/28/09 08:34 AM
Posts: 1,229 In The Hills
jughed
In The Hills
the factory motor mounts are eliminated when using a plate. less weight and more room for other stuff. this pic shows the Alterkation mentioned by 7074cuda. http://static.racingjunk.com/63/ui/2/02/2571131603796.jpg it's not cheap but makes plenty of room for headers, and dropped 85 lbs off the font end, oil pan choices are greater. it can be ordered with or without motor mounts (i chose without since a plate was to be used). and compared to the old suspenion, it drives like a new car.
[Re: Georg]
#206575
01/28/09 10:14 AM
01/28/09 10:14 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If this is a race only car you might want to move the engine back to the centerline of the car, it puts more weight on the centerline. Also if you do use the motor plate it is advised that you add torque reaction rods to hold the engine when you launch and can help save you a tailshaft
[Re: MR_P_BODY]
#206576
01/29/09 02:39 AM
01/29/09 02:39 AM
Georg
Europa, Estonia
Thanks for answers! I cant use aftermarket K-frame because of class rules where I race. K-frame have to be original. But I really want to use steering rack, much lighter, takes less room etc. BUT problem is Charger`s steering knuckles. They are not front but back of knuckle. So I need to install steering gear behind K-frame. There comes anouther problem - oil pan what is only 1/2" behind K-frame so there is no room. Seems only possebility is to cut and weld oil pan a bit for makeing room for steering rack? But where you install motor plate? I mean do is stands between block and timing cover and do it fasten to motor same bolts what holds timing cover to motor block?
Thanks Georg
Premium Performance
[Re: MR_P_BODY]
#206577
01/29/09 03:11 AM
01/29/09 03:11 AM
Posts: 793 Utah
topbrent
Utah
What are torque reaction rods?
[Re: topbrent]
#206578
01/29/09 04:47 AM
01/29/09 04:47 AM
Posts: 951 Temperance, MI
prochargedhemi
Temperance, MI
a torque rod mounted to the motor and the chassis lengthwise to stop forward and rearward movement
[Re: Georg]
#206579
01/29/09 04:52 AM
01/29/09 04:52 AM
prochargedhemi
Temperance, MI
Thanks Georg
you may have a little more luck with a unisteer kit. not sure what year you have but they make a kit for 68-72 b-bodies www.unisteer.com
