eed HELP POWER TOP WOMT GO UP OR DOWN #2065397
05/01/16 06:26 PM
05/01/16 06:26 PM
OH
junkyardmaxie Offline OP
Happy Birthday junkyardmaxie  Offline OP
OH
1964 dodge dart convertible when i got the car it worked ok now it wont go up or down ? can here motor running was wondering if there is a place to put fuild in ? and were is it ? its about like the hydraulic jack when it gets low on fuild .thanks for any help
Re: eed HELP POWER TOP WOMT GO UP OR DOWN [Re: junkyardmaxie] #2065432
05/01/16 07:29 PM
05/01/16 07:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes the pump has a tank in it and you add hydraulic fluid. It will be behind the rear seat. There should be a plug in the side of the tank. Do an online search for the procedure for fill and bleeding a convertible top motor. While you are working on it check for leaking lines or pistons.
Re: eed HELP POWER TOP WOMT GO UP OR DOWN [Re: junkyardmaxie] #2065442
05/01/16 08:03 PM
05/01/16 08:03 PM
Andrewh Offline
Andrewh  Offline
if you don't see fluid leaking somewhere behind the seat, then the pump gave up the ghost and probably needs a rebuild.
I have had one go bad like that before.
up till the 90 lebaron's the pumps were the same however, so you should be able to swap out one of those.
You should have the pistons retracted, ie top down before you fill.
if you over fill you can rupture stuff.
Re: eed HELP POWER TOP WOMT GO UP OR DOWN [Re: junkyardmaxie] #2065524
05/01/16 10:04 PM
05/01/16 10:04 PM
OH
OH
thanks for the help
Re: eed HELP POWER TOP WOMT GO UP OR DOWN [Re: junkyardmaxie] #2065601
05/01/16 11:36 PM
05/01/16 11:36 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
This site has some useful info:
http://www.topmotorrepair.com/
