tunnel ram dual quad scoop #2057147
04/18/16 08:00 PM
04/18/16 08:00 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I've seen them on TV, guy using ( or building ) a dual quad scoop
made of plexiglass, are these home made or you can buy it ?
What is the most efficent scoop for performance ?
Any infos.....
Dan
Re: tunnel ram dual quad scoop [Re: Wedgeman] #2057157
04/18/16 08:11 PM
04/18/16 08:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
All of what I have seen are homemade.. the most
efficient one will have the carb at close to 3/4"
below the bottom of the scoop inlet.. if you can..
add in a ideal entry(thats a volocity stack)
EDIT
You can see the height of my scoop.. thats not even
on a tunnel ram.. thats a tall single 1050 with a
ideal entry on it.. the carb itself is about 3" lower
than the bottom of the scoop
wave
Re: tunnel ram dual quad scoop [Re: Wedgeman] #2057185
04/18/16 09:07 PM
04/18/16 09:07 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Begin by calculating the scoop area, which will be smaller as the car gets faster.
Yes, I said smaller.
http://www.landracing.com/forum/index.php/topic,13396.0.html
The, as much interior volume as practical. Ideally, the carb air horns are in still air.
Boffin Emeritus
Re: tunnel ram dual quad scoop [Re: Wedgeman] #2057255
04/18/16 10:37 PM
04/18/16 10:37 PM
west palm beach, florida
modelmakerinc Offline
The clear scoops are to see the arm drop or flashlight during street racing, There is no other reason for them. They certainly are not more efficient.
This is the scoop I just installed on my Coronet, the rear is completely open to the windshield and cowl, and I have 3"x9 Dia K&N filters on the carbs still have another inch above the filter and the scoop is 8" max above hood surface.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: tunnel ram dual quad scoop [Re: Wedgeman] #2057291
04/18/16 11:10 PM
04/18/16 11:10 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That scoop looks good Modelmaker.
Wedgeman, if you do a search on Yellowbullet there is info there on who makes/sells the clear scoops and why they use them.
Re: tunnel ram dual quad scoop [Re: Wedgeman] #2057346
04/18/16 11:53 PM
04/18/16 11:53 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I looked at the Hilborn style scoop, are they any good ?
Re: tunnel ram dual quad scoop [Re: modelmakerinc] #2057370
04/19/16 12:20 AM
04/19/16 12:20 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s a very sexy scoop............. thumbs
Re: tunnel ram dual quad scoop [Re: Wedgeman] #2057373
04/19/16 12:21 AM
04/19/16 12:21 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
They are not any good with the way they have those single or twin mini air filters. The air never gets a chance to straighten out. If you are running a blower then the blower stacks the air and negates that problem. I like the style of the Hilborn scoop. I have two and trying to engineer a way to make it taller and get a standard Wix air filter element to fit the opening closer to the opening(front) of the scoop. I'm also fond the the Thunderbolt ram air system. I don't like the clutter and the tubing, whether plastic or aluminum as it heats up and holds the heat, and negates the cooler air charge.
Re: tunnel ram dual quad scoop [Re: Wedgeman] #2057378
04/19/16 12:38 AM
04/19/16 12:38 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Any infos.....
Dan
Chris Terry Racing..........about 2 miles from my shop builds them for a lot of guys
Re: tunnel ram dual quad scoop [Re: Monte_Smith] #2057530
04/19/16 11:32 AM
04/19/16 11:32 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
I once used a newspaper mailbox
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: tunnel ram dual quad scoop [Re: Wedgeman] #2057807
04/19/16 05:48 PM
04/19/16 05:48 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Hopefully DusterDave will see this thread, he had a large Hilborn scoop on his blown Hemi that had a big flat filter in the bottom of it.
Re: tunnel ram dual quad scoop [Re: Wedgeman] #2064682
04/30/16 12:32 PM
04/30/16 12:32 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
inovated racecraft sells those scoops you see on street outlaws,there like 200.00
Re: tunnel ram dual quad scoop [Re: Wedgeman] #2065254
05/01/16 12:55 PM
05/01/16 12:55 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Duster Dave used the Unifilter he persuaded into the scoop.
With these scoops the filters hold the scoop to the carbs.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: tunnel ram dual quad scoop [Re: Wedgeman] #2065501
05/01/16 08:45 PM
05/01/16 08:45 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
How do you evaluate the front area (mouth)needed for an engine ?
Re: tunnel ram dual quad scoop [Re: Wedgeman] #2065610
05/01/16 10:49 PM
05/01/16 10:49 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I had the scoop that BDS sold at the time. It didn't have any provision for a filter, so I had to fab something that held a flat K&N filter.
It was OK for driving around town, but at the track, I removed it.
hemi-itis has the newer style BDS scoop, where they increased the size so it could hold a pair of round filters.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: tunnel ram dual quad scoop [Re: Wedgeman] #2065734
05/02/16 07:41 AM
05/02/16 07:41 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Forget the air cleaner....I look at the engine !!! wow
Re: tunnel ram dual quad scoop [Re: Wedgeman] #2066853
05/03/16 10:46 PM
05/03/16 10:46 PM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
Any infos.....
Dan
http://innovativeracecraftfl.com/product-tag/lexan-carb-scoop-dual/
http://innovativeracecraftfl.com/product-tag/lexan-carb-scoop/
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
