2898070 Radiator #2064282
04/29/16 09:45 PM
04/29/16 09:45 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
Can anyone tell me what this radiator fits.Thanks
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: 2898070 Radiator [Re: stickman] #2064294
04/29/16 09:55 PM
04/29/16 09:55 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
'68 C body 383
Re: 2898070 Radiator [Re: B5 Bee] #2064308
04/29/16 10:04 PM
04/29/16 10:04 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
So this wouldn`t fit a E body.
Re: 2898070 Radiator [Re: stickman] #2064661
04/30/16 01:00 PM
04/30/16 01:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The brackets and how far they stick out for the 6 bolt shroud may be an issue , the bolt hole locations for how it bolts to the core support will probably need to be tweaked on passenger side also.
Direct drop in replacement , no. But you could swap on your E body brackets if you have them.
Re: 2898070 Radiator [Re: JohnRR] #2064883
04/30/16 07:11 PM
04/30/16 07:11 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
Thanks John. It is a nice radiator but doesn`t fit which is My luck and I don`t have any E Body brackets left. I can`t win.
