I would use the stretch specs. only and do each bolt on the bench and write it down
I've seen .0015 shorter differences(below the minimum stretched lengths) in lengths using the same torque spec. recommended by the rod makers using thier lubes, all brands
I've seen 30 ft lb differences on ARP 2000 bolts in the same set of Oliver billet steel rods to get them in the same spec. lengths
Same thing on the ARP 2000 bolts in the Molnar rods I've used
Not all torque wrenches read exactly the same
I don't own a degree gauge that I can use for torque plus so many degrees stretch method so I use the rod bolt stretch gauge method only now
EDITED
On bolts that recommend between .0059 to .0064 I shoot for the middle lengths, if it takes 60 lbs to get to .0059 and 75 lbs to get to .0064 I will leave that one long on at that spec. and then try using 65 lbs on the others and make sure they don't get overstretched
IHTHs
