Carrillo con rods #2063150
04/28/16 01:05 AM
04/28/16 01:05 AM
FastOne Offline OP
FastOne  Offline OP
I have a set of Carrillo con rods for small block, 7/16 bolts, CARR SPS 22 on the bolts, would anyone happen to know the torque & stretch specs for this set?
Re: Carrillo con rods [Re: FastOne] #2063206
04/28/16 04:28 AM
04/28/16 04:28 AM
Call Carillo/ CP and get the straight scoopdirectly from them thumbs scope I thought I had thier phone number in my book but I don't, sorry blush
Re: Carrillo con rods [Re: Cab_Burge] #2063215
04/28/16 06:05 AM
04/28/16 06:05 AM
FastOne Offline OP
FastOne  Offline OP
Thanks Cab, I sent an email & no reply, I'll ring, phone number is on their web site
Re: Carrillo con rods [Re: FastOne] #2063287
04/28/16 11:39 AM
04/28/16 11:39 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
my 7/16 carr bolts in my CHilds rods called for 90ft lbs of torque and measure the stretch, spec like .004-.007 IIRC,,,
I just did a quick googlalation check and found this.
C:\Users\c\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\4BRMFKAC\bolt_instructionsheet.pdf
Re: Carrillo con rods [Re: FastOne] #2063288
04/28/16 11:41 AM
04/28/16 11:41 AM
Moparnut426 Offline
Moparnut426  Offline
Re: Carrillo con rods [Re: FastOne] #2063289
04/28/16 11:43 AM
04/28/16 11:43 AM
Moparnut426 Offline
Moparnut426  Offline
Open the cp-carrillo link, go to rods, then hardware, then bolts, and the instruction sheet comes up and on page 2 the specs are there.
Re: Carrillo con rods [Re: FastOne] #2063297
04/28/16 12:15 PM
04/28/16 12:15 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I can look when I get home, for some reason 55 is sticking in my head.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Carrillo con rods [Re: FastOne] #2063482
04/28/16 04:52 PM
04/28/16 04:52 PM
I would use the stretch specs. only and do each bolt on the bench and write it down up twocents I've seen .0015 shorter differences(below the minimum stretched lengths) in lengths using the same torque spec. recommended by the rod makers using thier lubes, all brands work I've seen 30 ft lb differences on ARP 2000 bolts in the same set of Oliver billet steel rods to get them in the same spec. lengths shock puke Same thing on the ARP 2000 bolts in the Molnar rods I've used work Not all torque wrenches read exactly the same work shruggy I don't own a degree gauge that I can use for torque plus so many degrees stretch method so I use the rod bolt stretch gauge method only now thumbs EDITED
On bolts that recommend between .0059 to .0064 I shoot for the middle lengths, if it takes 60 lbs to get to .0059 and 75 lbs to get to .0064 I will leave that one long on at that spec. and then try using 65 lbs on the others and make sure they don't get overstretched scope IHTHs thumbs
Re: Carrillo con rods [Re: Cab_Burge] #2063672
04/28/16 11:30 PM
04/28/16 11:30 PM
FastOne Offline OP
FastOne  Offline OP
Thanks for all the comments & help, I'll follow up all of this
I did wonder how old these rods are but not to worry they are in perfect condition
