Oil Temp ? #2063381
04/28/16 02:13 PM
04/28/16 02:13 PM
Idabel,Oklahoma
Gary Robbins Offline OP
Idabel,Oklahoma
You guys that drive your street/strip cars on the street what do you consider to much temp for the oil !!
My pump gas smallblock goes to 215* after 10 miles of driving and stays there...Engine temp stays at 170* and is half filled (4.100 bore with a 4" stroke )!!
Has a oil cooler also !!
Re: Oil Temp ? [Re: Gary Robbins] #2063403
04/28/16 02:39 PM
04/28/16 02:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
NICE car man...............Sorry, no oil temp gauge in mine........ thumbs
Re: Oil Temp ? [Re: Gary Robbins] #2063408
04/28/16 02:43 PM
04/28/16 02:43 PM
Renton Washington
Triple Threat Offline
Renton Washington
I can't tell you about any of my older stuff.
But my 2010 Ram has oil temp in the digital display on the dash. Typically oil temp hangs right around coolant temp, 190-205. If i'm running it hard, climbing a hill while pulling oil temp can climb to 240. That's the hottest I've ever seen it and within operating range of most conventional oils. Synthetics can be go 300+ without worry.
215 doesn't scare me. I'd just keep an eye on the oil and if it starts to get ugly change it.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Oil Temp ? [Re: Gary Robbins] #2063410
04/28/16 02:44 PM
04/28/16 02:44 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
215 is fine, actually on the cool side of things. MOst modern cars run much hotter oil temps than that upwards of 250+. FWIW our 68 Camaro has a partial fill in the block and we see 240+ after driving it on the highway. Installed an oil cooler and got those temps down to 200+-. Had that fail and have not had one on it for years and been driving it at 240+ with no issues. If you use a synthetic oil 250+ will not be an issue at all.
Re: Oil Temp ? [Re: Gary Robbins] #2063456
04/28/16 04:20 PM
04/28/16 04:20 PM
Cab_Burge Online work
Cab_Burge  Online Work
My experiences with piston engine airplanes with a oil temp gauge and talking to oil company representative is that most non synthetic petrroleum based lubricants are good to 275 F before they start breaking down. Most standard brand ATF have a additive that starts to change colors from red to brown at 275 and is black by 325F work My airplane had a oil cooler thermostst and it ran righ at 190F in straight and level flying summer and winyer, it would get up to 230 F in the summer taking off from Phoenix aggresively (2000 Ft per mintue devil) to climb out of the heat.
I had a oil temp, tranny temp and water temp on my old Duster, non filled block making north of 650 HP with a roller cam oiling the valve springs full time would see about the same oil temps as the water temps. I did take the oil temp readings at the back of the block where the oil pressure is taken from so maybe that had something to do with that reading work
As long as your below 275F oil temps. your fine thumbs twocents
Most synthetics lubricants will run up to 500+ F before starting to fail according to Mobil Oil techs. IHTHs shruggy
Re: Oil Temp ? [Re: Gary Robbins] #2093587
06/17/16 04:53 PM
06/17/16 04:53 PM
indiana PA
moparbob498 Offline
moparbob498  Offline
indiana PA
Beautiful car man! My oil temps are around 120°, but I have a 8 at. pan, #12 an oil lines, Indy oil cooler & dual oil pick up, internal & external, my 2012 charger runs at 196° to 203° just below coolant temp in that 1
mopar or no car
Re: Oil Temp ? [Re: Gary Robbins] #2093646
06/17/16 07:09 PM
06/17/16 07:09 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Never seen hotter the 200 on mine,even on 30 mile highway drives. 1" of water in block. And a turbo heating things up. 8qt moroso pan, no cooler, 20w50 brad penn. Also on e85 which helps alot.
Re: Oil Temp ? [Re: Gary Robbins] #2093682
06/17/16 08:16 PM
06/17/16 08:16 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
Gary, great looking car, what oil cooler did you use, where did you mount it, could have some pics please, Im building a 2/3 filled 408 street engine running a typical mopar style water pump, 4 row aloy radiator, in sumer it can get to 110 outside but mostly sits on late 90's, just want to make sure im not going to have heating issues, will be running a clutch fan as well
Greg
Re: Oil Temp ? [Re: Gary Robbins] #2093685
06/17/16 08:19 PM
06/17/16 08:19 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
Greg
Re: Oil Temp ? [Re: Al_Alguire] #2093708
06/17/16 08:58 PM
06/17/16 08:58 PM
Az
Crizila Offline
Crizila  Offline
Az
up on the money!
Fastest 300
Re: Oil Temp ? [Re: Gary Robbins] #2093765
06/17/16 11:40 PM
06/17/16 11:40 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Yes be happy with 215 oil and 170 water, I call it perfect. I had to go a oil cooler to get there with my half filled 528 and 547 BB's, running 20/50 mineral, was seeing 250+ now 200-220 and 185 water. Are you on Synthetic or mineral ?
Yes nice car mate !!
1963 Plymouth Max Wedge
1971 Barracuda
