69 hemi charger radiator fan: 215 or 216? #2063430
04/28/16 03:19 PM
04/28/16 03:19 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Which fan should a 69 HEMI charger have? 215 or 216?
Or any of the 2 it doesnt really matter?
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2063448
04/28/16 04:02 PM
04/28/16 04:02 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
They flopped back and forth all the time but I think the 426 in 69 got the 215
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2063452
04/28/16 04:13 PM
04/28/16 04:13 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Its my understanding the 4 spd got the 215 and the auto the 216. The 216 is 1/2 inch larger
1969 Hemi Roadrunner 2nd owner
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2063460
04/28/16 04:28 PM
04/28/16 04:28 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
216
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2063473
04/28/16 04:40 PM
04/28/16 04:40 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Mine is a hemi 4 speed 69 charger
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2063522
04/28/16 06:40 PM
04/28/16 06:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
here's a screenshot from a thread from a couple of years ago scope
& the thread - 215 VS. 216
if you have a 3.54 car, maybe the answer is in there shruggy
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2063528
04/28/16 06:48 PM
04/28/16 06:48 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
mine is a 4.10 car!
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2063546
04/28/16 07:24 PM
04/28/16 07:24 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By domingo
mine is a 4.10 car!
then as I said at the start - 215
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2063549
04/28/16 07:30 PM
04/28/16 07:30 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I just happen to have a NICE 215 fan.....so 215 will be!!!!
thanks!!!
Im gonna check for straightness on the blades while turning it on a water pump i have bolted to a block..... and then I will also have it balanced just to be safe....dont trust an old fan that has been tossed around for years.
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2063552
04/28/16 07:34 PM
04/28/16 07:34 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Is the 215 that you have with the part number stamped on or printed?
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2063555
04/28/16 07:37 PM
04/28/16 07:37 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I have both styles of 215. I wonder why some had the stamped number and some didnt?
I need to do my 68 HEMI RR auto, and then my 69 HEMI Charger 4 speed. I was thinking Id use the 215 fans I have on those cars, and then the other 216 fans I have on my E Bodies.
Also, i guess all 216 fans had the inked number?
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2063565
04/28/16 07:47 PM
04/28/16 07:47 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
My opinion is the stamped number is correct and the inked number would be the replacements
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2063566
04/28/16 07:51 PM
04/28/16 07:51 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
i picked the stamped one for my 69 charger which is my numbers matching car. wink
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2063791
04/29/16 01:56 AM
04/29/16 01:56 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Both 215 and 216 came stamped and inked,
stamped ones shown here.
Difference in blade of both shown as well
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2063831
04/29/16 06:19 AM
04/29/16 06:19 AM
moparx Offline
moparx  Offline
how will you balance it if needed ? static or dynamic balance ? add or remove weight and where ? i'm curious, as i have never seen this done. thanks in advance. please take pics.
beer
Re: 69 hemi charger radiator fan: 215 or 216? [Re: moparx] #2063976
04/29/16 01:34 PM
04/29/16 01:34 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Unless something is missing,rivet or metal I would see no need to balance. twocents
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2064249
04/29/16 09:03 PM
04/29/16 09:03 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Which fan should a 69 HEMI charger have? 215 or 216?...
In my opinion, based on research I have done in the past, the 215 is correct fan blade for a '69 Hemi 4spd.
The 1969 Chrysler parts book shows the 215 for the Hemi (auto and 4spd), and the 440 (4spd only). You may notice there is a mistake in book, the Hemi is not listed for B body cars. shruggy confused
The 1969 Chrysler service manual also shows the same fan blade used on Hemi auto and 4spd, and 440 4spd only cars.
This info also agrees with the BC sheet info from Dan.
You have a good 215 blade you said, so great! up
Parts book info and service manual info below.
Re: 69 hemi charger radiator fan: 215 or 216? [Re: 62maxwgn] #2064598
04/30/16 11:42 AM
04/30/16 11:42 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I dont think thats true. Any fan that has had any kind of misshandling will vibrate badly. And will cause stress to the blades and rivets that hold the blades on the center spider. The fact that the fan is attached to something heavy and solid such as an engine and wont make you notuce is out of balance doesnt mean its ok!!!
If not just watch how any hosehold fan will vibrate to destruction when you mes just ever slightly with any of the blades.
An unbalanced fan will mess up your water pump a lot faster. Not to mention it can come apart while in operation and mess your car bad....or even worde kill you.
I will balance mine even if it takes to put a non original rivet here and there on the blades.
I just dont trust a fan that has been kicked around amd tossed in storage for 40 years!
Re: 69 hemi charger radiator fan: 215 or 216? [Re: moparx] #2064604
04/30/16 11:49 AM
04/30/16 11:49 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
beer
Dynamic. Usually balance is corrected by making sure the blades are even and centered and with the same pitch and then balance is corrected by adding weight via special balancing rivets on the blades.
Re: 69 hemi charger radiator fan: 215 or 216? [Re: moparfan53] #2064605
04/30/16 11:51 AM
04/30/16 11:51 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
YES Im gonna use the 215.
I am gonna save my 216s for the E Bodies!!
