Re: E body torque boxes [Re: RROD] #2062998
04/27/16 09:56 PM
04/27/16 09:56 PM
Parsippany, New Jersey
340challconvert Offline
My A66 Challenger 340 convertible has them on both front and rear.
1970 A-66 340 Challenger convertible
Re: E body torque boxes [Re: Morty426] #2063016
04/27/16 10:15 PM
04/27/16 10:15 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Originally Posted By Morty426
Torque boxes are probably the product of axle packages, motors, body type and what the line worker felt like doing that day.
Tell us what type of car you have and maybe we can tell you if it likely had torque boxes.
70 six pak challenger.
Re: E body torque boxes [Re: RROD] #2063312
04/28/16 12:48 PM
04/28/16 12:48 PM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
my lowly 318 71 barracuda has both built june 14 had 7.25 rear axle
Re: E body torque boxes [Re: GVH] #2063321
04/28/16 12:58 PM
04/28/16 12:58 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Most 71s have the fronts. Having the rears would be odd for that application unless it was a convertible
Re: E body torque boxes [Re: RROD] #2063409
04/28/16 02:43 PM
04/28/16 02:43 PM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
I agree with Morty426 - I've never seen the rears on a 70 or 71 with that engine application.
Re: E body torque boxes [Re: RROD] #2063527
04/28/16 06:47 PM
04/28/16 06:47 PM
Social Republic of California
fc7vw9 Offline
fc7vw9  Offline
My 71 383 4 speed, A31 axle package has front, my 70 440 auto 355 8 3/4 has front and rear, and my 70 340 auto air has front and rear, also has rear sway bar (torque boxes seem original, rear sway cant tell, LA built no broadcast sheet). I had a 71 GC 318 auto air no torque boxes.
Re: E body torque boxes [Re: RROD] #2578610
11/15/18 01:35 AM
11/15/18 01:35 AM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
forgot to mention my 71 318 7 1/4 is a convertible
Re: E body torque boxes [Re: RROD] #2578814
11/15/18 04:32 PM
11/15/18 04:32 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
they are technically frame connectors.
they connect the front and rear framerails through the rocker panel, which btw convertibles had heavy 1/4" angle iron spot welded to the inside of the rocker panels for rigidity.
i had a 1970 318 i forgot if it were 3 or 4-speed on the floor, but it had front and rear tork boxes, i would assume a factory mistake.
