Re: 727 Output shaft support fit in trans
[Re: SlickRS23]
#2062770
04/27/16 04:26 PM
04/27/16 04:26 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
First off if you bought a GOOD USED PART from auto trans supplier that is a BOLT IN Sprag , what you purchased is a replacement part to fix a sprag that spun in the case , which rarely happens.
Bolt it tight to the case, tighten the set screw and restake the case around it and it will hold pretty much like it did when new ... but it won't spin again ...
What was your reason for buying this part ?
[Re: SlickRS23]
#2062795
04/27/16 04:59 PM
04/27/16 04:59 PM
Posts: 25,801 Rio Linda, CA
John_Kunkel
Rio Linda, CA
In '71 the factory revised the fit of the output shaft support from press-fit to slip-fit. If you have a '71 or later support (fully interchangeable with '66-'70 supports) it should be a slip-fit.
[Re: SlickRS23]
#2063337
04/28/16 01:19 PM
04/28/16 01:19 PM
JohnRR
U.S.S.A.
Thanks JohnRR, My original sprag was slightly loose in the case, so I replaced it with a bolt-in. That installed very nice and tight. What I was referring to is the output shaft support.
I wasn't really sure what part you were talking about but ... what John K said .... What is the number that is cast onto the support ?
