Page 3 of 4 1 2 3 4
Re: new 500" stroker motor wont spin clear around? [Re: Runner] #206309
01/29/09 01:46 AM
01/29/09 01:46 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I'd reserve all judgement until the problem is found.Like what has been said,be there as it is being dis-assembled.Don't be surprised if some thing is found on top of a piston.Do you have or have access to a borescope?Do you know which cylinder is near the top of it's stroke when it locks?You can determine this by turning the engine until it stops,back it up and
put your finger over the plug hole to feel pressure. Also if it's a blower motor,check your pully bolts on the front of the crank and make sure one is not interfearing on the timing cover.Check the same on the blower.
everyones always so quick to pass judgement.
When you spend nearly $4500 in parts, and pay an engine shop $1500 for machine work, assembly, clearancing, etc. you tend to get a little jumpy when something's not right. If I'm going to spend $6000 on an engine build, that's something I don't want to do twice. I know everyone is human and we all make mistakes, but you have to wonder, if they missed something simple, what else did they miss? (that is, unless it was your fault because you dropped a nut down the intake or whatever)
**Photobucket sucks**
Re: new 500" stroker motor wont spin clear around? [Re: 70Cuda383] #206310
01/29/09 11:03 AM
01/29/09 11:03 AM
New Haven County CT
Mr 5 Speed Offline
Mr 5 Speed  Offline
New Haven County CT
Curious about the findings also. You mentioned almost completing 340 +/- a few degrees of rotation. I may need some educating here but if something was on top of any piston, wouldn't it only turn over 180 =/- a few degrees since every piston comes up twice ?? Sames goes for a rod bolt since they also make 2 passes (2 up/2 down) in 360 degrees. Someone clear that up for me. To clear this up for me, are you turning the engine around 180 degrees and calling that 360 since technically your balancer has made a 360 degree revolution but the engine has only completed one cycle?
Re: new 500" stroker motor wont spin clear around? [Re: Mr 5 Speed] #206311
01/29/09 11:13 AM
01/29/09 11:13 AM
God's Country Maryland
GODSCOUNTRY340 Online content
GODSCOUNTRY340  Online Content
360 degrees crank rotation the piston comes up once, not twice. You're thinking of camshaft rotation.
Re: new 500" stroker motor wont spin clear around? [Re: GODSCOUNTRY340] #206312
01/29/09 11:24 AM
01/29/09 11:24 AM
West Virginia
B1Frank Offline
B1Frank  Offline
West Virginia
That is why i took my motor to Mike at muscle motor's, it did cost more, but way better in the long run !!!
Re: new 500" stroker motor wont spin clear around? [Re: GODSCOUNTRY340] #206313
01/29/09 11:25 AM
01/29/09 11:25 AM
New Haven County CT
Mr 5 Speed Offline
Mr 5 Speed  Offline
New Haven County CT
Gotcha. Thanks for that. So if he is describing 360 crank rotation then everyones guess of something on top of the piston, interference with the pickup, or rod bolt clearance completely makes sense to me now.
Re: new 500" stroker motor wont spin clear around? [Re: GODSCOUNTRY340] #206314
01/29/09 11:32 AM
01/29/09 11:32 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
720 degrees of crank for every 360 of cam.
It could be 1 of a 100 things. Give this shop
some time to get it figured out.
I've seen Jason Line make mistakes (very few)
and he get's it figured out.
Will soon find out.
Snap your neck, mega G-force launch, is all I want!
Re: new 500" stroker motor wont spin clear around? [Re: BDS871Cuda] #206315
01/29/09 01:37 PM
01/29/09 01:37 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
the motor got dropped off at the builder today and he didnt find anything on the piston laying. said it looks like something is hitting in the bottom end.
he is going to tear it down today and work on it until its fixed.
Re: new 500" stroker motor wont spin clear around? [Re: dirt] #206316
01/29/09 01:44 PM
01/29/09 01:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Glad to see it wasnt your fault, he'll fix you up,
he doesnt want to have anything bad said about him.
Its probably like Chuck said that the crank is crashing
the pick up
Re: new 500" stroker motor wont spin clear around? [Re: dirt] #206317
01/29/09 02:12 PM
01/29/09 02:12 PM
New York
polyspheric Offline
polyspheric  Offline
New York
everyone screws up once in a while
He did, but you didn't (unless you still owe him money).
It's nice if he fixes it - but who pays you for your wasted time and trouble?
When it's fixed he owes you a favor, money, or a discount on future work (if he's smart that will be his choice)
Boffin Emeritus
Re: new 500" stroker motor wont spin clear around? [Re: polyspheric] #206318
01/29/09 10:01 PM
01/29/09 10:01 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
got a call. the builder said it was the timing gear on the crank for the gear drive. it was broke and came apart when he took the cover off.
we didnt even mess with it so thats pretty wild.
it was a milodon gear drive. never heard of that breaking on a motor that was never even cranked before!
he said he looked at his notes and he set the valve lash so he would have had to turn the motor when he built it and it was fine then. i am not sure who is going to pick up the bill for the tear down and reassembly. he called milodon to see what they said.
Re: new 500" stroker motor wont spin clear around? [Re: dirt] #206319
01/29/09 10:08 PM
01/29/09 10:08 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Never would have guessed that
Re: new 500" stroker motor wont spin clear around? [Re: dirt] #206320
01/29/09 10:09 PM
01/29/09 10:09 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
no way he can blame the crank gear on you.
it must have beena tight fit.beat it on or something.it will be a week or 2 before you get it back togather.keep us posted on things as you go. GOT BOOST?!
Re: new 500" stroker motor wont spin clear around? [Re: dirt] #206321
01/29/09 10:43 PM
01/29/09 10:43 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
That's interesting...
That gear on those units are very beefy. Seems inconceivable, but? One of the necessary steps to set up a Milodon is to remove the factory timing cover pins in the block, set the "lash" between the gears and redrill the block to accept the oversize pins. I would imagine that if this wasn't done(or done improperly) that you could have a problem. Possibily some debris wound up wedging itself between the gears?? All speculation without actually seeing it.
Keep us posted.
MB
Re: new 500" stroker motor wont spin clear around? [Re: blownzoom440] #206322
01/29/09 10:45 PM
01/29/09 10:45 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Don't sound right to me Would love to see a picture of that sprocket
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: new 500" stroker motor wont spin clear around? [Re: hemi-itis] #206323
01/29/09 10:51 PM
01/29/09 10:51 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
SO much better that you found it now than at 6500 rpm later
Re: new 500" stroker motor wont spin clear around? [Re: aarcuda] #206324
01/29/09 11:13 PM
01/29/09 11:13 PM
North West,Ohio
SSDA3426 Offline
SSDA3426  Offline
North West,Ohio
Aint That The Truth......
Some things MULTI-MAKES Builders just don't know what to look at....I can't tell ya how many people that have called me or bought at swap meets from me a Flex Plate Because Their ENGINE BUILDER NEEDS IT TO BALANCE THE ASSEMBLY.....CHEVY BOYZ!!
Like one of the other members was saying Muscle Motors are on their Game.I have learned little things here and there working with them and being Sponsored By them over the years...Little things that even you yourself as a Professional Engine Builder wouldn't think of...Mike Really Knows what he's doing...
Good Luck!!
SS
Re: new 500" stroker motor wont spin clear around? [Re: dirt] #206325
01/29/09 11:50 PM
01/29/09 11:50 PM
long island new york
K
kingdust Offline
kingdust  Offline
K
like some one else said, better now than through the traps! if they determine that it was a defective gear he might try and hit you with a labor cost. but if he did install it incorrectly and if he's honest and wants your business again he will say, listen i made a mistake and i'll take care of it. keep us posted good luck.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: new 500" stroker motor wont spin clear around? [Re: kingdust] #206326
01/30/09 12:18 AM
01/30/09 12:18 AM
any chance you could take a picture of that gear and post it? it's hard to imagine one of those breaking.
Re: new 500" stroker motor wont spin clear around? #206327
01/30/09 12:51 AM
01/30/09 12:51 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
OK, here is what im thinking, I had a problem with the lower gear on my gear drive. The engine builder put it together and the gear did not set flush against the crank. The mopar 4" stroker crank has an outside radius and the crank gear was not machined with a radius. It kept the gear 3/16" from flush against the crank. I found out when my pulleys would not line up when installed. What im thinking is if its got a stroker crank with an outside radius and the gear was installed and just tapped back with out checking to see if it was flush, then when the balancer was installed it broke the gear by forcing it onto the radius......My ....Phill
Re: new 500" stroker motor wont spin clear around? [Re: 9 Sec Phill] #206328
01/30/09 12:56 AM
01/30/09 12:56 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
yep, and im sure he heard it, or was his beer cans in oil pan...
MOPAR OR NO CAR
Page 3 of 4 1 2 3 4
