Page 3 of 5 1 2 3 4 5
Re: pros and cons of solid flat tappet vs solid roller [Re: mopar dave] #2062602
04/27/16 10:59 AM
04/27/16 10:59 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I will give you great advice.
Call Dwayne Porter, go with his suggestion, and have him order you a cam.
He knows 100% what he is doing and that takes the guesswork out of it.
I have personal experience using his help, and the cams worked perfect.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: pros and cons of solid flat tappet vs solid roller [Re: DARTH V8Я] #2062659
04/27/16 01:02 PM
04/27/16 01:02 PM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By DARTH V8R
Originally Posted By Street Monkies
Look at it this way. You probably aren't going to go fast enough to need anything more then a flat tappet cam. Plenty of 8 and 9 second cars running flat tappets. I like the rollers as well, but look at the cost difference. Unless you're trying to run way in the 8s, or just anal about having a roller those would be the only reasons I could see why to have one... I really wanted to run a roller in my motor, but at least for now due to cost I am going flat tappet.
guess that's why every car manufacturer today runs hydraulic flat tappet cams.Cause they ain't running 8's.
I just knew this one would come up. Apples and oranges!!
Fastest 300
Re: pros and cons of solid flat tappet vs solid roller [Re: 383man] #2062689
04/27/16 01:53 PM
04/27/16 01:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By 383man
Originally Posted By Thumperdart
Well again boyz and girlz, been STREET DRIVING a .680-.660 276-281 @ .050 for 8+ years w/out ANY ISSUES what so ever kinda like my 8" vert and spool...........REAL WORLD not "I HEARD" BS...........
Thumper have you pulled your lifters and had them rebuilt any time ? Or are you saying you have run 8 years on the same roller lifters ? Course I dont know how much you drive on the street but I know you do drive it on the street. Ron
Had em rebuilt once just because they felt a little funny rollen em on my fingers and that was about 6 years ago when I drove it weekly. I drive it less now but what`s funny is the 276 cam mentioned is the cam in my car and it`s got gentle ramps w/low stable spring pressures. When I went 9.98 it had 210 on the seat and drove it that way for several years. ADD a [censored] and I think it`s been closer to to 10 years........ work
Re: pros and cons of solid flat tappet vs solid roller [Re: mopar dave] #2062690
04/27/16 01:53 PM
04/27/16 01:53 PM
an8sec70cuda Offline
Only downside to the roller is cost IMO.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: pros and cons of solid flat tappet vs solid roller [Re: Crizila] #2062693
04/27/16 01:59 PM
04/27/16 01:59 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
How so?
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: pros and cons of solid flat tappet vs solid roller [Re: DARTH V8Я] #2062712
04/27/16 02:28 PM
04/27/16 02:28 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
For race cars I think smaller motors benefit more from a SR in that a big motor can take more seat to seat duration down low and still be responsive "enough" below the torque peak while at the same time can get adequate .050-up cylinder filling for the heads/peak power RPM from the flat tappet. A comparable flat tappet generally needs more (beyond) peak lift to be comparable so you can get the same effective peak lift duration, and in some cases you can be limited by the steepness of the ramp you can put on a flat tappet. That was (in the early days) a Big part of the reason mushroom tappets were developed.
With a smaller motor it can benefit more from a tighter seat to seat while using the roller lobe to "catch up" at the higher lifts, a smaller motor generally has a narrower powerband to begin with so anything you can do to broaden the powerband window tends to make it more consistent.
my .02 FWIW...interesting thread though...I'm enjoying it popcorn
WIZE
In Car:
Re: pros and cons of solid flat tappet vs solid roller [Re: DusterDave] #2062714
04/27/16 02:29 PM
04/27/16 02:29 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Originally Posted By DusterDave
The big con with a flat tappet cam is, if your break-in procedure wasn't done perfectly, and/or you are not using the correct oil (which is getting harder to find locally anymore)
I'm pretty sure those little bottles of ZDDP (zinc) are still available?
you run the risk of some lobes going round, and really messing up your crank, bearings and piston skirts. It happened to me, and many, many others.
I can see the wear particles from the cam & lifters being thrown into the cylinder bores by splash, but how would they get through the oil filter to the crank and bearings? shruggy
Nobody's mentioned the old "Mini-Express" mushroom cam/lifters P3690588 (316 adv. @ 0.654) and there's a bigger one 328, 0.690. Lifters are a PITA to change but the few people who have run one have had good things to say about the performance. I think it's around 270 duration @.050. A lot cheaper than a roller setup... work
Re: pros and cons of solid flat tappet vs solid roller [Re: mopar dave] #2062728
04/27/16 03:07 PM
04/27/16 03:07 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Hydraulic rollers in production engines like the LS7 7.0L that turn 7,000 rpm with a 100k warranty wasn't in anybodies wildest dreams back in the '60s/70s/80/90s. Heck, 10 years ago we would have all thought that this kind of performance was impossible. These are street grinds with over 0.600-inch valve lift too. Sure, solid flat tappet cams can make more peak horsepower at the strip, but it can't touch rollers for the area under the curve and all round street performance. PLUS you can reuse roller lifters as often as you want.
Re: pros and cons of solid flat tappet vs solid roller [Re: B3422W5] #2062733
04/27/16 03:27 PM
04/27/16 03:27 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
yes i will give Dwayne a call, but when i'm ready to buy.
Re: pros and cons of solid flat tappet vs solid roller [Re: DARTH V8Я] #2062735
04/27/16 03:31 PM
04/27/16 03:31 PM
Mt Morris Michigan
Mt Morris Michigan
yeah, but whos making a hyro roller lifter for mopar that can spin 7000+ without heavy springs?
Re: pros and cons of solid flat tappet vs solid roller [Re: Streetwize] #2062737
04/27/16 03:35 PM
04/27/16 03:35 PM
Mt Morris Michigan
Mt Morris Michigan
I understand where your coming from with that and i agree, but i do not want agressive ramps that eat up springs. I want longevity in this build as well.
Re: pros and cons of solid flat tappet vs solid roller [Re: mopar dave] #2062759
04/27/16 04:11 PM
04/27/16 04:11 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
beehives how yah think those engine make 100k without wearing out parts.
Re: pros and cons of solid flat tappet vs solid roller [Re: mopar dave] #2062760
04/27/16 04:12 PM
04/27/16 04:12 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
The roller Dwayne specc'ed for me was in the car 8 years when i sold it( and I raced it way more than you, and street drove it all the time) with only 1 spring change in all those years.
Never a single issue.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: pros and cons of solid flat tappet vs solid roller [Re: DARTH V8Я] #2062807
04/27/16 05:10 PM
04/27/16 05:10 PM
Mt Morris Michigan
Mt Morris Michigan
how many top performance cylinder head shops you know that are suggesting and using beehive springs? Not too common around here. I even asked Ryan Johnson about beehive springs and he wanted nothing to do with them. Maybe there more common now but i hear nothin g of them around here.
Re: pros and cons of solid flat tappet vs solid roller [Re: B3422W5] #2062809
04/27/16 05:11 PM
04/27/16 05:11 PM
Mt Morris Michigan
Mt Morris Michigan
Cool? Ill be talking to him soon.
Re: pros and cons of solid flat tappet vs solid roller [Re: mopar dave] #2062813
04/27/16 05:14 PM
04/27/16 05:14 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Been available for years.
http://www.hughesengines.com/TechArticles/1beehivespringsretainers.php
But anyways it sounds like you already made up your mind, good luck thumbs
Re: pros and cons of solid flat tappet vs solid roller [Re: mopar dave] #2062836
04/27/16 05:46 PM
04/27/16 05:46 PM
Washington
madscientist Offline
Washington
I will say I was on the beehive bandwagon for a while then got off it hard. Had way too many failures. If you call PAC and ask them for a spring for anything with what I would call a performance lobe, they don't suggest beehives. I was burned two years ago with beehives and that will be the last time.
Just becaus the OE's do something, doesn't mean it translates into the performance world.
I just broke in my SFT with 145 on the seat and 345 over the nose (.620 gross .606 NET) and used Torco break in oil with no issues. If you get it running and th lifters spin they won't go flat. I never use additives. I want th guy who designed the oil to put in it what he thought best.
BTW and FWIW I will use Torco 5w30 synthetic when it comes off the dyno.
Re: pros and cons of solid flat tappet vs solid roller [Re: mopar dave] #2062855
04/27/16 06:06 PM
04/27/16 06:06 PM
central ohio
N
nss guy Online happy
nss guy  Online Happy
N
central ohio
You plan on spinning 511ci 7000+rpm on the street?
Why?
Re: pros and cons of solid flat tappet vs solid roller [Re: nss guy] #2062864
04/27/16 06:27 PM
04/27/16 06:27 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Why?
For some reason Mopar guys love over-reving their engines and doing wheelies that break stuff and oil down tracks.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: pros and cons of solid flat tappet vs solid roller [Re: nss guy] #2062871
04/27/16 06:30 PM
04/27/16 06:30 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
My 517 routinely spins 6800+, went 7200 more than a few times. It has a Bullet 264/268 @.050 Hydraulic roller with the Crane lifters....BUT(!!!) These Heads also have the Race W2 Style billet one piece Shaft hold downs (Chapman stage VI's) which are much stronger and more stable than a Cast-In-Head Pedestal....and ports that are happy to feed it up there. Never rev'ed it higher than that...but with the new ported 337 intake it may want to go even a little higher.
I'm not sure it would rev that high or that stable with cast-in pedestals....I can't say 'cause I never had a 500" BB willing to rev this high. I do know the fact that they are Hydraulic rollers don't seem to hold it back at all, this one rev's just like a Solid roller. I think the HR (or any valvetrain) ability to rev has about as much to do with geometry and stability (and minimal oscillation) as it does with sheer mass. twocents
all else being equal one would think a low deck might rev a little higher than an RB....the pushrods are ~3/4" shorter and proportionally a bit lighter.
WIZE
In Car:
