Re: new 500" stroker motor wont spin clear around?
[Re: dirt]
#206271
01/27/09 09:07 PM
01/27/09 09:07 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Make sure the flex plate bolts are all the way in the convertor and the convertor is all the way on the input shaft.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: Pat7272]
#206273
01/27/09 09:26 PM
01/27/09 09:26 PM
Posts: 530 MI
kjh440
MI
[Re: Pat7272]
#206274
01/27/09 09:26 PM
01/27/09 09:26 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: dirt]
#206276
01/27/09 09:32 PM
01/27/09 09:32 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
We just pulled the stroker motor off the engine stand to put in the car and i thought we should check the bellhousing to see if it was lined up correct and the crank will not spin 360 degrees around. it hits the same spot either way you spin it. it probably spins about 345 degrees from shere it stops around the other way until it hits. i didnt build the motor a local race engine builder built it but i cant imagine this is normal? almost seems like one of the rod bolts or crank is hitting. its a 440 block stroked to 500" any ideas?
I had the same problem with mine. In my case the crank counter weight was hitting a spot on the block. I had to grind the block to make clearance. I found it once I put the crank in. I guess the questions other have asked is valid. Did it turn before you put it in?
[Re: dirt]
#206282
01/27/09 10:30 PM
01/27/09 10:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Since a local builder did the job, load it back up and take it back to him without opening it up... let him take care of it
[Re: rowin4]
#206288
01/28/09 07:45 AM
01/28/09 07:45 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
If it was me, I would have just lost confidence in the engine builder, and I would let him know that. I'd call him and tell him that it won't turn over all the way, maybe take it and show him, and then tell him that you now have reason to doubt the quality of his work, and will be taking it somewhere else for a full inspection. you will deduct any cost from what you owe him. if you already paid him, then you could try to invoice him for it, or cancel the credit card payment in full, and work it out afterwards.
unless you are familiar with the builder, have done work with him before, or know his work from other buddy's or friends of yours. if it was my first time there, and I had no history with them, I'd be extremly suspect of the rest of their work.
but, then again, I had a machine shop hose me on SEVERAL items that I discovered during my build up.
For example:
A) I spec'd the pistons to be .005 in the hole. calculated it out, knowing the deck height, rod, stroke, compression height, etc. it should have been .005 in the hole. on mock up, they called me and said "it all spins pretty good, everything checks out great. by the way, this thing is zero deck" when iwas putting it together myself, I measured them, and they were not zero deck, they were where they should have been, .005 in the hole!
B) I asked them to mock it up for me and check piston to valve clearance, and tell me what length pushrods I needed. I ordered the size they told me I needed, and they were .500" too long! the valves wouldn't even close! (apparently they forgot to switch out the solid lifter they used during mock up, to a hydraulic lifter for checing pushrod length)
C) they said they put it all together and it spun around great. when I put it together, the crank wouldn't even move because the main bearings needed to be shaved to work with my crank
D) After lots of mis-communication, confusion, and lack of understanding on how I wanted it balanced, I fired them and picked up all my stuff. they quipped at me "by the way, that cam is no good. it won't make enough vacuum to shift your transmission" I reminded them that the flywheels are for manualtransmissions, flex plates are for automatics, and it's a mopar, there is no vacuum signal needed for the automatic transmission!
--there's more that I could go into, but, you get the idea
so, if they missed that one tiny thing (oil pick up--if that's what it is) ask yourself...what else did they miss?
**Photobucket sucks**
