indy 440-25 users i have a question. #2062672
04/27/16 01:28 PM
04/27/16 01:28 PM
OHIO THE HEART OF IT ALL
64hemi330sedan Offline OP
do you seal the carb spacers on the top of the manifold with sealer?
Re: indy 440-25 users i have a question. [Re: 64hemi330sedan] #2062691
04/27/16 01:56 PM
04/27/16 01:56 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Yes - just a thin layer - you want to avoid any potential leaks with that intake - hope you have some blow off valves installed! Its a good intake but when they light off and lift the lid it will make your heart skip a beat!
Re: indy 440-25 users i have a question. [Re: 64hemi330sedan] #2062973
04/27/16 09:13 PM
04/27/16 09:13 PM
Wisconsin
1964maxwedge Offline
Wisconsin
I use anaerobic sealer if you use rtv sealer it can make fun to it get off
Re: indy 440-25 users i have a question. [Re: DoubleD] #2063176
04/28/16 02:07 AM
04/28/16 02:07 AM
lol! word on the streets is to NEVER! spin the engine then hit the ignition.
Re: indy 440-25 users i have a question. [Re: 64hemi330sedan] #2063225
04/28/16 08:16 AM
04/28/16 08:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've tried making a gasket. Bolts kept coming loose. Cut a small slot in the upper half of the intake 1/4" x .060". That way you can get a screw driver between the half's, otherwise very difficult to pry the top off with RTV. I pump the accelerator 3 times, let it set 30-45 seconds, then 1 pump and crank with ignition on, starts pretty easy unless 50 or below. Then through a fender cover over the carbs when it starts yank it off.
Doug
