Who's Radiator Are You Running? #2062356
04/26/16 11:21 PM
04/26/16 11:21 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'm heavily considering an AFCO Double-Pass radiator for my 5.7L swap.
http://www.speedwaymotors.com/AFCO-80130NDP-Extra-Capacity-Double-Pass-Universal-Radiator-LH-Filler,39530.html
Champion has a nice bolt-in for $210, but I am not quite a fan of the down flow with the inlet/outlet on the same side. I can't help but feel there would be significant stagnant flow toward the driver's side.
What else is out there?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Who's Radiator Are You Running? [Re: GoodysGotaCuda] #2062367
04/26/16 11:41 PM
04/26/16 11:41 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Not a Hemi swap, but I used an Afco dual pass when I did the Torana's engine swap and it is a nice quality (American made, or they were at least, hopefully still are!) radiator.
Keeps it cool even with the a/c on even on the hottest days idling, running, what ever..
Re: Who's Radiator Are You Running? [Re: GoodysGotaCuda] #2062371
04/26/16 11:47 PM
04/26/16 11:47 PM
USA
hudsonhornet7x Offline
USA
I have a wizard unit. Very nicely built, and made in the US.
Re: Who's Radiator Are You Running? [Re: GoodysGotaCuda] #2062476
04/27/16 02:25 AM
04/27/16 02:25 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I run a Be Cool 60176 crossflow the biggest one they make for big block engines. The outlets are on opposite side but the engine dosen't care. I run 2 Gates Green stripe hoses with an aluminum coupler for the bottom hose.
No problems at all at the track!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Who's Radiator Are You Running? [Re: GoodysGotaCuda] #2062494
04/27/16 02:53 AM
04/27/16 02:53 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
26" Dual pass from speedway motors. Maybe $150
Re: Who's Radiator Are You Running? [Re: sixpackgut] #2062710
04/27/16 02:24 PM
04/27/16 02:24 PM
dogdays Offline
dogdays  Offline
The term "dual pass" is their way of saying 2-pass. In heat exchangers this means the tank end with the hoses has a divider in it that essentially cuts the core in half. So coolant flows in and crosses the core in half of the tubes. When it reaches the other side there's no place for it to go than across the tank and through the other half of the radiator, exiting at the other hose.
Result: the cooling water does not flow from inlet to outlet, bypassing the core.
I have also seen 3-pass radiators.
R.
Re: Who's Radiator Are You Running? [Re: GoodysGotaCuda] #2063597
04/28/16 09:01 PM
04/28/16 09:01 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks all, I ended up going with the simple solution. $210 26" Champion radiator for the 3G Hemi conversion.
It's not my ideal radiator, but it gets one in the car with the least amount of fuss and ought to be more than fine for this low HP application.
The car needs to get back on the road ASAP!
2020 RAM 1500
Re: Who's Radiator Are You Running? [Re: GoodysGotaCuda] #2064985
04/30/16 10:27 PM
04/30/16 10:27 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
US radiators triple pass optima 4 core, got it through Classic industries, I went with the copper brass because it looks original and cools well beyond what my hemi puts out. Tim
http://www.usradiator.com/dodge-charger-1966-69-v8-bb-radiator-2354.html
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Who's Radiator Are You Running? [Re: GoodysGotaCuda] #2065136
05/01/16 09:14 AM
05/01/16 09:14 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I got a Saturday off from class and managed to get my radiator in, not too many things left to install before I can ship the car for paint! It's a shame the polished tanks aren't optional, because I won't be leaving it that way. laugh2
2020 RAM 1500
