Correct finish 1969 charger dual exh hanger
#2061575
04/25/16 07:14 PM
04/25/16 07:14 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
How should this be finished from the factory?
Gloss black?
Semi gloss black??
Bare metal?????
This is on a 1969 hemi charger
Re: Correct finish 1969 charger dual exh hanger
[Re: domingo]
#2063226
04/28/16 08:27 AM
04/28/16 08:27 AM
Posts: 601 Mass
charge70
Mass
Domingo,I'm restoring my brothers 70 Charger R/T right now.An original car he's owned since 1982.When I removed that hanger bracket it was bare steel no paint or plating.All it had on it was surface rust and a small splattering of undercoating when they undercoated the bottom of the car.Also,when I removed the hanger you could see the grey body dip primer color under the mounting flanges,so this piece is put on after the car was run thru the dip tanks.Hope this helps you out.I have some pics,PM me your e-mail address and I can send a few to you. John
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: domingo]
#2531565
08/04/18 05:41 PM
08/04/18 05:41 PM
domingo
EL Master
EL Master
Lima, Peru
Great info. I had not seen this reply, this was quite a while ago!!!
[Re: domingo]
#2531588
08/04/18 07:16 PM
08/04/18 07:16 PM
Posts: 1,551 Sweden
71redcuda
Sweden
