A Body Barracuda Spare Tire/Rim Size #2061991
04/26/16 01:33 PM
04/26/16 01:33 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
What is the correct size rim and spare tire for an A body Barracuda? Need to get the right size for mine.
Thanks!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: A Body Barracuda Spare Tire/Rim Size [Re: Erik] #2062013
04/26/16 02:36 PM
04/26/16 02:36 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
for 1968 it would be the same that's on the car.
the largest combination for 340-383-A/C-some others had 14x5.5" wheels & E70-14 tires.
Re: A Body Barracuda Spare Tire/Rim Size [Re: Erik] #2062018
04/26/16 02:41 PM
04/26/16 02:41 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Thanks. When in the spare well, should the top of the tire be flush with the trunk floor or does it rise above the trunk floor? The spare I have now rises above the trunk floor so the board is above the rest of the floor. Is that correct?
Re: A Body Barracuda Spare Tire/Rim Size [Re: Erik] #2062028
04/26/16 02:50 PM
04/26/16 02:50 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I think all of the 14x5.5" wheel/tire spares are above the trunk floor.
the 13" & 14x4.5" available combos sit "more flush".
Re: A Body Barracuda Spare Tire/Rim Size [Re: Erik] #2062061
04/26/16 03:38 PM
04/26/16 03:38 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Thanks!
Re: A Body Barracuda Spare Tire/Rim Size [Re: 6bblgt] #2063512
04/28/16 06:15 PM
04/28/16 06:15 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Yes and it's ugly that way. If you want a clean look, use the narrower wheel.
Re: A Body Barracuda Spare Tire/Rim Size [Re: Erik] #2063807
04/29/16 03:14 AM
04/29/16 03:14 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
If the factory provided fiberboard spare hold-down cover is used, it will eventually crown or droop over the edges of the 5.5" wheel/tire. Personally I won't say this is ugly, but in time the fiberboard won't be flat anymore.
Photo shows a flat fiberboard cover under the mat on a 5.5" wheel that is higher elevation than the rest of the trunk.
Re: A Body Barracuda Spare Tire/Rim Size [Re: kentj340] #2066757
05/03/16 09:45 PM
05/03/16 09:45 PM
pass christian, ms
69fish Offline
69fish  Offline
pass christian, ms
I want to say my 69 barracuda spare tire was a C 78-14 on a 4.5 inch rim. It sat flush.
Re: A Body Barracuda Spare Tire/Rim Size [Re: kentj340] #2066758
05/03/16 09:46 PM
05/03/16 09:46 PM
pass christian, ms
69fish Offline
69fish  Offline
pass christian, ms
Re: A Body Barracuda Spare Tire/Rim Size [Re: Erik] #2066792
05/03/16 10:21 PM
05/03/16 10:21 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
The original trunk mat had a mat of 1" or so of a horsehair type of padding glued to the underside of the trunk mat on either side of the spare tire cover to raise the mat so that it was pretty flat
Re: A Body Barracuda Spare Tire/Rim Size [Re: RoadRunnerJD] #2066976
05/04/16 03:55 AM
05/04/16 03:55 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Interesting. My car with 5.5" wheels was not delivered with that padding.
