Page 5 of 5 1 2 3 4 5
Re: Toyota Alternator Upgrade [Re: Scamp408] #2045335
04/03/16 02:21 PM
04/03/16 02:21 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I measured 5" from front to rear of case on Denso 210-0106 (Toyota 60A, V belt)
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Toyota Alternator Upgrade [Re: Scamp408] #2047331
04/05/16 07:48 PM
04/05/16 07:48 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I am gunna test fit with toyo alt once I get my pump. If I have room it looks like I need the JD one.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2047735
04/06/16 09:51 AM
04/06/16 09:51 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I eyeballed mine last night. I have Andy's brackets on a RB, and it looks like I have enough clearance to the head, just not sure how close the 3 pin plug will come to #2 primary.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2048192
04/06/16 06:35 PM
04/06/16 06:35 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
The small blocks are tight especially with aluminum heads
Re: Toyota Alternator Upgrade [Re: Scamp408] #2048475
04/06/16 11:56 PM
04/06/16 11:56 PM
Victoria B. C Canada
gold66cuda Offline
gold66cuda  Offline
They are, in fact I had to notch the front of the head for my 70 amp unit to fit. This was on and early small block with the cast iron water pump though.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2048480
04/07/16 12:01 AM
04/07/16 12:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I made a bracket that mounts on the fuel bolts..
I use the 85a denso
wave
Re: Toyota Alternator Upgrade [Re: Scamp408] #2061582
04/25/16 07:22 PM
04/25/16 07:22 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Just got an alternator from a 97 4Runner today. The plug is different than the one Andy has for sale but I'm sure I can figure it out. Gonna call powermaster about a pulley.
eBay-cdwmotorsports
Re: Toyota Alternator Upgrade [Re: Scamp408] #2061795
04/26/16 01:14 AM
04/26/16 01:14 AM
Martinsville, IN
Martinsville, IN
The shaft measures out around .52" and the pulley is 2.4" in diameter.Powermaster was closed and nothing in their catalog seems as if it will fit. Any other sources for a pulley?
eBay-cdwmotorsports
Re: Toyota Alternator Upgrade [Re: Scamp408] #2061882
04/26/16 08:30 AM
04/26/16 08:30 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I got my pulley from a briggs Stratton dyhaitsu diesel engine for a Toro 3250 golf course mower. It's comes off a small denso alt 40amps
Re: Toyota Alternator Upgrade [Re: Scamp408] #2061883
04/26/16 08:31 AM
04/26/16 08:31 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I fitted up the 60 amp and have a little less than a1\4in between head and back of alt.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2062753
04/27/16 04:02 PM
04/27/16 04:02 PM
NWPA
Q
QMopar Offline
QMopar  Offline
Q
NWPA
What are the bracket options for folks running a big block with AC?
Re: Toyota Alternator Upgrade [Re: QMopar] #2062935
04/27/16 08:01 PM
04/27/16 08:01 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Here's the kit I used but I used a Gm powermaster alt.
http://bouchillonperformance.com/inc/sdetail/467/571
They have another bb kit also.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2062956
04/27/16 08:34 PM
04/27/16 08:34 PM
Martinsville, IN
Martinsville, IN
Jones Racing Products sells a pulley, that's who Powermaster sent me to for a V groove pulley.
97 4Runner alternator takes part #AL-3105-B-A-2.375 if you are running a DMI pulley
eBay-cdwmotorsports
Re: Toyota Alternator Upgrade [Re: Scamp408] #2063026
04/27/16 10:25 PM
04/27/16 10:25 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Jones is a killer place, super nice products and quality.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Toyota Alternator Upgrade [Re: Scamp408] #2064191
04/29/16 07:34 PM
04/29/16 07:34 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Ran it today with the 60amp toyota and all was good fan came on volts went down but came up and stabilized.Only issue I have and had is when the fan comes on the rpm drops alot no matter what i do.Happens with 90 amp denso mopar ext reg alt also.
Re: Toyota Alternator Upgrade [Re: Scamp408] #2065276
05/01/16 02:29 PM
05/01/16 02:29 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Wondering if this drop in rpm will happen with the 120or 140 JD unit
