Re: Exhaust hangers - how many and where?
[Re: DrCharles]
#2061597
04/25/16 07:43 PM
04/25/16 07:43 PM
Posts: 2,094 central texas
krautrock
central texas
i did the x pipe in my 67 coronet, i found some factory tabs on the floor board that i was able to run some bolts into and drop the hangers from... right there where the floor runs up some for the hump for the axle, think where the pinion snubber would touch and look about 12" outside the center there.
[Re: DrCharles]
#2062111
04/26/16 04:54 PM
04/26/16 04:54 PM
krautrock
central texas
Yes, there are tabs there (that's pretty close to the rear of the mufflers). I plan to use those.
Did you hang your system anywhere else from the headers back to those factory tabs? those are the only hangers on mine, i didn't go all the way out the rear though. if had gone all the way to bumper i would've fab'd some kind of mount back there too probably.
