Re: exhaust "bangs"
[Re: paddel]
#2061317
04/25/16 12:10 PM
04/25/16 12:10 PM
Posts: 5,924 ohio
ruderunner
ohio
Sounds like an exhaust leak. When it's rich exhaust (as in coasting down from revving) the extra air allows the fumes to reignite in the exhaust. Usually in a muffler as they are the likely places for the excess fuel to collect.
Check for leaks at all connections. Could be a loose clamp or bad header seal or..
Angry white pureblood male
Re: exhaust "bangs"
[Re: paddel]
#2093569
06/17/16 04:31 PM
06/17/16 04:31 PM
Posts: 107 germany
paddel
germany
Should I also lean out the idle mixture a little bit? As I richened a bit much after rebuilding the carb for more performance. Keep in mind that I also recurved the distributor quite a bit because of my low compression.
I'll also change my old very dirty air filter for a new one. Maybe that also leans out the mixture just a tiny little bit. I have one of those aftermarket cleaners as I can not find an original one here in germany.
Re: exhaust "bangs"
[Re: paddel]
#2093649
06/17/16 07:15 PM
06/17/16 07:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Only time I ever had that happen I had an intermittent plug wire bad issue, it's not fire the plug, and the next cylinder on that side would fire the mixture on it's exhaust stroke. Sounded like a putt inside the car, but more like a gunshot outside and a flame would shoot out the exhaust.
Re: exhaust "bangs"
[Re: paddel]
#2093655
06/17/16 07:34 PM
06/17/16 07:34 PM
Posts: 13,609 md
mopars4ever
md
Re: exhaust "bangs"
[Re: paddel]
#2094421
06/19/16 01:50 PM
06/19/16 01:50 PM
Supercuda
About to go away
About to go away
up yours
Lean provides more power than rich, rich provides a safety margin.
A miss is causing your "banging", it's raw fuel igniting in the exhaust, not the engine.
Re: exhaust "bangs"
[Re: paddel]
#2094810
06/20/16 03:53 AM
06/20/16 03:53 AM
Posts: 107 germany
paddel
germany
I got that it is in the exhaust. I thought, that a rich (or too rich) mixture would cause the fuel not to burn completeley, flow into the exhaust and bang.
What I also learned is that a richer mixture will provide more power. You want to have all the oxigen to be part of the burning process. To achieve that you want to use a bit richer mixture. So that every oxigen molecule has it's fuel. If you run lean, not every oxygen molecule has a "partner" and goes out unused. And how much air goes in, is regulated by your foot. So you realy want to use every bit of it. Running lean just saves fuel. That is what I've learned and it makes sense.
I hope I got that right and I am understandable. My english is far from perfect.
EDIT: I forgot to write something else. I also learned that a too lean mixture can cause misfire, because the mixture will detonate early. But I think then it would go out through the intake.
