Page 4 of 6 1 2 3 4 5 6
Re: SB Victor heads [Re: Brian Hafliger] #2061145
04/25/16 12:15 AM
04/25/16 12:15 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
So can you run six cylinder head studs with this head? How does the top row work?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: SB Victor heads [Re: 1967dartgt] #2061254
04/25/16 09:51 AM
04/25/16 09:51 AM
moparx Offline
moparx  Offline
i must have missed it, but how far off are the flange holes on the headers ?
beer
Re: SB Victor heads [Re: moparx] #2061281
04/25/16 10:52 AM
04/25/16 10:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
beer
Go back to the pics on page 1 and see for your self
wave
Re: SB Victor heads [Re: MR_P_BODY] #2061291
04/25/16 11:03 AM
04/25/16 11:03 AM
moparx Offline
moparx  Offline
thanks mr. p. i goofed again. i forgot about seeing those ! blush gettin' old sucks. sometimes i can't remember what i had for supper !
beer
Re: SB Victor heads [Re: CJD AUTOMOTIVE] #2061369
04/25/16 01:46 PM
04/25/16 01:46 PM
AndyF Offline
AndyF  Offline
Originally Posted By CJD AUTOMOTIVE
Originally Posted By AndyF
Looks like a fun project. The bolt pattern on the exhaust seems wrong to me. Wonder what the designer was thinking there? The other choices on the head seem to make sense.
It is wrong. Rick sent me pics of when he machined the first sets. I ask him about them and if they raised the exhaust bolt holes enough when the port was raised. He doubled checked and they didn't. He told me TTI was already making headers based on the wrong position, so they weren't going to change it. He did say he had Cometic making an exhaust gasket for the pattern. He also said a standard W5 gasket will fit, and just barely not cover the port, but does bias the header to the bottom of the port.
Ha, that is too funny. They raised the port but forgot to raise the bolt holes. Umm, some sort of rookie running the CAD system over at Edelbrock these days??
Re: SB Victor heads [Re: Brian Hafliger] #2061480
04/25/16 04:15 PM
04/25/16 04:15 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
While the headerboltsituation may be less than perfect and should have been sorted out but i realy dont think its going to be a problem to seal the headers.
Re: SB Victor heads [Re: Brian Hafliger] #2061554
04/25/16 06:27 PM
04/25/16 06:27 PM
ccarson Offline
ccarson  Offline
If I didn't have so much money wrapped up into this W9 set up
I would try the Victors.
Re: SB Victor heads [Re: 1967dartgt] #2061713
04/25/16 10:54 PM
04/25/16 10:54 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Did they change the way they bolt on or not?
Re: SB Victor heads [Re: Brian Hafliger] #2061725
04/25/16 11:08 PM
04/25/16 11:08 PM
Socal
littleVAL Offline
littleVAL  Offline
Socal
Seems like you could add tabs on the exhaust flange and drill a couple off extra holes in the head. The center in particular would respond well to another bolt in the center at the top
Re: SB Victor heads [Re: Brian Hafliger] #2062245
04/26/16 08:51 PM
04/26/16 08:51 PM
Queensland Australia
moparmacka Offline
moparmacka  Offline
Can't wait mate.......I'm bursting at the seams to see how these things go. It has been a long time coming and its a pitty I invested so much into my W5's.
All we need is someone to do decent blocks and look out for the small block brigade!!!!
Andrew
Re: SB Victor heads [Re: Brian Hafliger] #2062304
04/26/16 10:01 PM
04/26/16 10:01 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
I hate that exhaust bolt locations, I mean they spent all this time and effort just to put out a head that look like it fell off the back of Cooter's trailer. How do you as this huge company even allow something to leave your shop that way.....
I guess either W9 or going to gen III Hemi will still be in my future
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: SB Victor heads [Re: slammedR/T] #2062641
04/27/16 12:32 PM
04/27/16 12:32 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Touche! Somebody finally said it.
[img] [/img]
Re: SB Victor heads [Re: clonestocker] #2062643
04/27/16 12:40 PM
04/27/16 12:40 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
After how many years of saying you want to get it right!!
Re: SB Victor heads [Re: 1967dartgt] #2062950
04/27/16 08:29 PM
04/27/16 08:29 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
And knowing there are aftermarket parts suppliers who have to make parts according to the screw up rolleyes
They need to correct it now IMO
Re: SB Victor heads [Re: Brian Hafliger] #2067279
05/04/16 05:25 PM
05/04/16 05:25 PM
sst404b Offline
sst404b  Offline
Started work on our heads Monday. They flowed 364 @ 800 ootb and with a valve job and clean up of tool marks went 380 @ 800. They are going on 440 inch Ritter block 4.185 x 4 and will be up and running next week. Edlebrocks site now shows big block victor rockers and Houghes has them ready to ship, ours arrived yesterday.This stuff is the real deal and will make big inch small blocks easier to build,as the parts are now available. Also the exhaust bolt pattern is W2 and our old 2in headers bolt up without adapters.I will update as we get closer to dyno day. Ive got some pics but dont know how to post.
Ray
Re: SB Victor heads [Re: sst404b] #2067978
05/05/16 09:42 PM
05/05/16 09:42 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Ray
Can you use the top row of head studs? Did they change them from the proto type?
Re: SB Victor heads [Re: Brian Hafliger] #2068012
05/05/16 10:49 PM
05/05/16 10:49 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
thanks for the additional info Ray.... hope you can post some picts up!
Re: SB Victor heads [Re: sst404b] #2068071
05/06/16 12:41 AM
05/06/16 12:41 AM
SoCal
Brian Hafliger Offline OP
SoCal
Ray
How do you like that block? Any other details? What power are you expecting?
Brian
Brian Hafliger
Re: SB Victor heads [Re: 1967dartgt] #2068073
05/06/16 12:43 AM
05/06/16 12:43 AM
SoCal
SoCal
Nope...
Brian Hafliger
Re: SB Victor heads [Re: Brian Hafliger] #2068202
05/06/16 11:31 AM
05/06/16 11:31 AM
CJD AUTOMOTIVE Offline
Not to hijack the thread, but spoke with Don Flanagan at Crower yesterday, and the Crower stainless rocker shafts for this head will be ready in about 4 weeks....so I'm told. You will have to mill the cast stands and bolt on their steel stands and rockers. Just an option for you guys wanting to run high spring pressures or endurance applications.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
