Re: New spin on an old question - 400 in a Charger
[Re: 70Coronet500Vert]
#2048178
04/06/16 06:17 PM
04/06/16 06:17 PM
Posts: 6,445 Missouri
68KillerBee
Missouri
68KillerBee
I had no idea the FITech were so affordable. I thought these were still $2500.
For under $1500 I can get the fuel sump and FI setup. That is good news. Plus I believe summit has $100 off and if you're lucky you can find a discount code through summit on top of that. You can search here on moparts for reviews on that product. I know feets is going to get it and has friend/s that have it also. If you rebuild the heads, you definitely are better off buying a set of aluminum by the time you add up the cost. My dad stuck a good chunk of change in his stock iron heads and nothing crazy was done to them. I got the 440source stealth heads and they were around a grand. Stock out of the box they performed great. If you're patient, you can find a used set to save some cash. Now I've had them CNC ported and all that good stuff, but stock performed wonderfully.
#2048640
04/07/16 08:41 AM
04/07/16 08:41 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
Is it worth doing head without a cam? even the reasonable cams mentioned on this thread?
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
#2048695
04/07/16 10:37 AM
04/07/16 10:37 AM
DaytonaTurbo
Manitoba, Canada
I would do one of the summit cams. Good choice for this application IMO and very cheap.
#2049489
04/08/16 08:52 AM
04/08/16 08:52 AM
70Coronet500Vert
St Charles MO
Yeah, we will be purchasing that this weekend after the compression check. Of course, provided it is not snowing......
#2050203
04/09/16 06:00 AM
04/09/16 06:00 AM
Posts: 523 Right here
HP2
Right here
Is it worth doing head without a cam? even the reasonable cams mentioned on this thread? Or put it this way: -Why buy new heads? Weight is one factor, but the better flowing heads need higher compression to do any good. Well, are your heads in bad condition it's another story. Do a compression test and post the numbers here. If some cylinders are down, then do a leak-down-test. Add a cam that builds more cylinder pressure and get the EFI from FiTech as a start. Like someone said, Summit has good and cheap cams. You don't even have to take the engine out in this first step. No reason for overkill if you want a daily driver. Would be very interesting to put it in a chassis dyno before and after!
70 W100 Power Wagon. 318 4-spd 70 Sport Fury 440 2dr HT 71 Duster 340 71 Charger Super Bee - 383/727 72 Charger "Sabotage" - 440/727 - Street/Strip 78 Warlock in beautiful patina
[Re: HP2]
#2050486
04/09/16 04:55 PM
04/09/16 04:55 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Is it worth doing head without a cam? even the reasonable cams mentioned on this thread? Or put it this way: -Why buy new heads? Weight is one factor, but the better flowing heads need higher compression to do any good. Well, are your heads in bad condition it's another story. Do a compression test and post the numbers here. If some cylinders are down, then do a leak-down-test. Add a cam that builds more cylinder pressure and get the EFI from FiTech as a start. Like someone said, Summit has good and cheap cams. You don't even have to take the engine out in this first step. No reason for overkill if you want a daily driver. Would be very interesting to put it in a chassis dyno before and after! Better flowing heads need more compression to do any good? Why do you say they need more compression? I've put better heads on a less than 8:1 440 and seen substantial increases in horsepower.
#2061244
04/25/16 09:01 AM
04/25/16 09:01 AM
70Coronet500Vert
St Charles MO
Gentlemen,
Finally did the compression check. Plugs looked good in all cylinders. Nice tan color.
I had 120 - 125 in all cylinders except 1 and that cylinder was 140.
Book says minimum of 100 with less than 40 psi from cylinder to cylinder.
Book says this is a 8.2:1 compression ratio engine.
At any rate, we are installing FITech unit soon and then this may be a fixture on the st Louis roads between st Charles and alton.
