A-body roof structure welds - Room for improvement #2060440
04/23/16 07:53 PM
04/23/16 07:53 PM
The Netherlands
BigBlockMopar Offline OP
The Netherlands
I was installing some Dynamat-like mats on the inside roof sheetmetal today and noticed the shabby welds the factory made on these cars.
I plan to add some extra welds to tie everything together a bit more.
Also 'interesting' to see was how weak the design of the roof span is. Almost like it's ment to be able to flex with the car's body structure.
Thinking of adding some extra welds here and maybe add some gussets.
Roof span connection/bracket;
Factory welder guy having a bad day?
Few welds, and right at the corner where the A-pillar goes down, the metal is fatigue cracked. Same on the other side. (Notice the thin vertical rustline).
I'm thinking these manually made welds where made firstly to just hold/mockup together the individual frame pieces, after which the spotwelder welded everything together.
Re: A-body roof structure welds - Room for improvement [Re: BigBlockMopar] #2060491
04/23/16 10:10 PM
04/23/16 10:10 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
I'm more curious about the sound-deadening material you used.
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: A-body roof structure welds - Room for improvement [Re: BigBlockMopar] #2060507
04/23/16 10:52 PM
04/23/16 10:52 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
What is the raised dot pattern for?
Re: A-body roof structure welds - Room for improvement [Re: jcc] #2060520
04/23/16 11:17 PM
04/23/16 11:17 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
secret messages in brail.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: A-body roof structure welds - Room for improvement [Re: BigBlockMopar] #2060577
04/24/16 12:52 AM
04/24/16 12:52 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Those cars were lucky to get down the line at all with the QC going on back then.
Mopar to the bone!!!
Re: A-body roof structure welds - Room for improvement [Re: BigBlockMopar] #2060657
04/24/16 07:30 AM
04/24/16 07:30 AM
The Netherlands
The Netherlands
The raised dots were ment for the blind guy doing the welding at the time of course... duh laugh
The sound deadening sheets are simple rubber/bitumen sheets with a self-adhesive coating on one side.
When you warm them up they get very soft and moldable. The glue gets real tacky makes mounting easy.
Re: A-body roof structure welds - Room for improvement [Re: BigBlockMopar] #2060745
04/24/16 12:14 PM
04/24/16 12:14 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
So what happens to the glue when the roof gets hot in the Summer? Perhaps that's not a problem in the Netherlands. wink
2020 RAM 1500
Re: A-body roof structure welds - Room for improvement [Re: BigBlockMopar] #2060763
04/24/16 12:48 PM
04/24/16 12:48 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
My roof crossbeam wasn't even welded on one side and my a-pillar welds were just as ugly as yours - just the way they were built back then
Re: A-body roof structure welds - Room for improvement [Re: BigBlockMopar] #2060765
04/24/16 12:57 PM
04/24/16 12:57 PM
Los Osos, Ca
CKessel Online content
CKessel  Online Content
Los Osos, Ca
I would recommend punching some holes in the outer layers with a Rotabroach holesaw to make some additional attachment points. Looks like you have plenty of room on those flanges to add in a bunch of plug welds to tighten things up.
Carl Kessel
Re: A-body roof structure welds - Room for improvement [Re: ntstlgl1970] #2060825
04/24/16 02:28 PM
04/24/16 02:28 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Yes, yet get a look at some roll-overs in the wrecking yards and everything stays in one piece. shruggy Jaws invented to get people out.
Nice, clean metal you have there. up If it was on a rotisserie I would flip it over and put half a roll of 023 into it and button it all up.
Tight as a drum then, need less matting. twocents
Mo' Farts
Moderated by "tbagger".
Re: A-body roof structure welds - Room for improvement [Re: BigBlockMopar] #2060926
04/24/16 06:30 PM
04/24/16 06:30 PM
The Netherlands
The Netherlands
I'll see what happens with the glue when the temps go up in the next months. Was worried about that too.
Today, I've added plenty of ugly welds of my own to the area. But I'm pretty sure nothing, if any is flexing anymore here.
My camera "wouldn't focus" on my ugly welds so no pics.. wink
I've added a simple 2" x 1.75" gusset on both sides of the roofspan.
Below's a sketch of the gusset placement.
Could do more gusseting, but that wouldn't benefit much more because the span itself isn't that sturdy.
Re: A-body roof structure welds - Room for improvement [Re: BigBlockMopar] #2061362
04/25/16 01:38 PM
04/25/16 01:38 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
It already is gusseted. shruggy Just follow and weld up the joints that are already there. twocents
Mo' Farts
Re: A-body roof structure welds - Room for improvement [Re: BigBlockMopar] #2062114
04/26/16 05:01 PM
04/26/16 05:01 PM
The Netherlands
The Netherlands
The roofspan itself has flimsy tabs on the sides, so even if the bracket could be made 'bulletproof', it won't do much for strength on the span itself.
I don't feel further welding would improve much. Besides that, the car is a running daily used driver with full interior and vinyl roof.
Welding the span and roofframe to the roofskin didn't seem like a smart idea laugh
Re: A-body roof structure welds - Room for improvement [Re: BigBlockMopar] #2062910
04/27/16 07:19 PM
04/27/16 07:19 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Most of the structure comes from the roof skin, that is why the welds are not that critical on the frame work...tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
